Direct fit AWIC kits on the way.
Front, Top, Air, Water.
Turbo_Carl
Re: Direct fit AWIC kits on the way.
Post by Turbo_Carl »
kimokalihi wrote:What was the cost of everything? I could look....but it would be nice to just have that info here. I like the video and you should make more of the rest of the install. Did you have to cut anything to mount that heat exhanger in the bumper?
Rest of the video is going to be posted soon. I have to merge some stuff together and edit it. I will explain everything there.
Parts list will be posted along with the vid. Everything together cost me $530 or so. (Military Discount too) Probably would cost everyone else about $550 or so.
ride_child wrote:what if you take out the ac system and use the exchanger from that as the one for the awic? just thinking...
inlet and outlet are too small. It won't work. You have to buy a proper heat exchanger.
1993 SS. 5MT, STI Fuel Pump, Custom Intake, Diamond Coil Pack, Forge BOV, Hallman MBC, Custom AWIC, CNT 3" Downpipe, SLP Resonator, Carbon Muffler, TD04, FCD
1987 Ford T-Bird Turbo Coupe (Pikes Peak Hill Climb Car)
It'll be more for me aince I'm buying a reservoir for mine. Extra $100 there.
Turbo_Carl wrote:inlet and outlet are too small. It won't work. You have to buy a proper heat exchanger.
Just to add to this....the AC condenser is the wrong type of exchanger for water and will have a rather large amount of back pressure...if it worked at all.
ride_child
Post by ride_child »
Ahh gotcha haha just a thought! Thanks guys!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
martimus919
Post by martimus919 »
Nice work! Subscribed
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
Turbo_Carl
Well it's all installed. System was very easy to bleed with that extra filler cap.
Did a stress test at 15psi (don't go that high unless you have an upgraded fuel system) drove for 20 mins and the intercooler was ICE COLD when I pulled over to check it.
ICE COLD
I consider this install a great success! Everything works PERFECT!
Full video to be released tomorrow. I made a few mistakes on the install and had to backtrack, and ya'll are lucky because I will explain everything to look out for and expect.
Awesome!
Any way to test pre- and post-intercooler temps?
I've already ordered my probes and multimeter setup specifically for that but I won't have an awic for quite some time.
Turbo_Carl wrote:Well it's all installed. System was very easy to bleed with that extra filler cap.
ICE COLD
Alright, Lets get that info!!!
James614
Post by James614 »
I'm curious to see the before/after temps, and how they compare to the performance we've seen from WRX TMIC's.
Got my temp probes and multimeters today and installed them. Check it out here: http://bbs.legacycentral.org/viewtopic. ... 39#p390239
I don't have the AWIC yet but this gives a good idea what the WRX TMIC is like. Keep in mind I don't have a splitter or any type of intercooler ducting but I might get one soon.
James614
Post by James614 »
I've seen before that pre-intercooler temps can be close to 300*, but it's just so crazy to imagine that and then see turbocharged (and supercharged) cars stock with no intercoolers!
I'm guessing the cars that are stock with no intercooler must not be creating as much heat. I can't imagine blasting 250+f air into your engine.
James614
Post by James614 »
I've seen on here before from someone with a VF-11 and no intercooler, and the temps were right around 250 max if I recall correctly.
Turbo_Carl
Sorry for the delay on the vid. Mixture of editing software not cooperating and being stuck at work too much. I saved the full vid last night and will post to youtube today.
Patiently waiting for video.
Turbo_Carl
kimokalihi wrote:Patiently waiting for video.
about an hour left on the upload
Turbo_Carl
Watched it probably 3 hours before you updated your thread haha. Thanks for the info.
Post by SILINC3R »
Nice video and it looks great would like to do that but I want to keep my A/C as it's hot as shit here is Alabamer.
See....the folks up in the PNW think it's no big deal to pull your AC ;)
Come live down south and you'll want to put extra AC in :lol:
Turbo_Carl
All it requires to keep A/C is a smaller heat exchanger really. That's it. The compressor and a/c lines had no effect on the placement of the Intercooler or water lines. The only option from silicone is to run two heat exchangers in series. Which that bosch pump will have no problem with to be honest. I will swing by silicone intakes and make a vid in a couple days to show how to do it.
James614
Post by James614 »
Just want to point out that if you pull your A/C system, your A/C button works as a radiator fan switch, handy for when you want to cool the system while sitting (between Auto-X runs, for example). I almost bought and installed a dedicated switch for the fans before I realized this. If you drag race or auto-x you'll definitely want some fan control.
Turbo_Carl
James614 wrote:Just want to point out that if you pull your A/C system, your A/C button works as a radiator fan switch, handy for when you want to cool the system while sitting (between Auto-X runs, for example). I almost bought and installed a dedicated switch for the fans before I realized this. If you drag race or auto-x you'll definitely want some fan control.
I was first considering using the A/C as the switch for my pump, but decided to go with a dedicated switch to be safe.
