I haven't found much local support by searching, and Calgary is a very expensive city in general (looking at $40 per injector without new screens or o-rings), so I started looking at places I could ship my injectors for service.
Witchhunter has stopped service outside of the USA, so I was looking for other places.
Accurate Injector Service, based out of Arizona, looks like a nice option. For $25 per injector they test before and after, clean, replace seals etc., clean the rails, pressure test in the rail and ship back installed.
http://accurateis.com/store/before_after_01a.php
I asked them if they will ship to Canada.
Injector cleaning, including rails and o-rings
Dynamic Entry
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Re: Injector cleaning, including rails and o-rings
There is a place in Kelowna that the guys have had good luck with, maybe Interior Injection or Okanagan Injection. They cleaned/balanced injectors for bmxkelowna and nosyt, maybe PM them to see. I think it may have been around $100/set?
99 Outback
92 Legacy Turbo 5 speed
Dynamic Entry
So after I pulled the rails with expectations of shipping them for service, I noticed that my leaky injector in question did not have its cap tightened down.
I couldn't see that from above when they were in. I suppose if I'd thought to check I might have felt it or seen from the right angle.
The screws turned easily and the cap went flush. So I assume that would eliminate the leak I had observed.
So now it is a choice of long term versus short.
Could send them both to be cleaned and rebuilt since they are already out.
Or, since the only seal exposed was the spacer, I could replace those ans put them back in as is. I would then trust all the seals and be able to determine if tightening the cap fixed the problem.
Sent from my Nexus One using Tapatalk 2
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Dynamic Entry
I mailed them to AIS today.
I'm curious to see the before and after test data, and it will be one component I don't need to worry about going forward.
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Good plan
