Hi guys,
I have a Legacy '91 with EJ22M N/A and I'm Turbo swapping. I'm in need of a wiring diagram to connect my Apexi AFC NEO to my car. Any links or jpg's out there?
- Kristjan
ECU Wiring Diagram to connect Apexi AFC NEO
KristjanJohann
Subaru Legacy GX '97 [BG]
Subaru Legacy GX 2.2 Turbo '91 [BF7]
Subaru Leone GLX '86 [AC5] Getting EJ22T
Suzuki GSX-R 750 '90
Mazda 626 '81
Subaru Legacy GT '97 [BK6] Sold
Subaru Forester '00 [SF] Sold
and maaany moooore :D
http://www.flickr.com/kristjanjohann
Mazda 626 '81
Re: ECU Wiring Diagram to connect Apexi AFC NEO
There are two links in this thread for the SAFC II manual. Not sure if that's what you need though.
http://bbs.legacycentral.org/viewtopic.php?f=15&t=36138
KristjanJohann
Ok thanks Josh
I have all I need now. Just one small thing.
I have A/F in and A/F out but I have 4 A/F wires + ground in my ecu pinout... any ideas.
Mazda 626 '81
Mazda 626 '81
The MAF sensor, also what they're calling air flow meter should 12V power, ground, & signal. Some of the MAF's had additional wiring which was used to detect the incorrect MAF sensor being used. You want to use the MAF signal wire to tie into the AFC.
