upping boost after rebuild
how many miles should i put on the rebuilt motor before upping the boost
Re: upping boost after rebuild
Most do about 1000 break in miles, I did on my motor.
and after i raise the boost a lil should i run a colder plug
it did thanks. i plan to go to 11 or 12 psi so i think my reg plugs should be ok
Regular plugs will be fine. I run stock plugs and stock gap at 18psi with absolutely no issues.
Yes, just use the normal plugs. There's no need to go to a colder plug.
