I went ahead swapped the oil pressure sensor out with a cleaned up one and the same issues occur: Went ahead and got a oil compression tester and its really not looking very positive. I'm seeing <10psi on idle and at peak, around 40-50psi at rpm. Clearances on the bearings should all be standard and I guess its possible there is an issue with oil pump but it seems unlikely right now.
I was under the impression 5w30 would be fine as a break in oil but I'm gonna take a series of steps before doing anything too drastic. Picked up some generic 10w30 and a much better filter.. Definitely going to take a good look at the oil and possibly pull the pan and check out the pickup this weekend if things don't improve.
Car isn't leaving the garage again until I get to the bottom of this low oil pressure business. Not cool.
