Rally X then huge boom.... need help
devilzdriver
Post by devilzdriver »
Well gang the fun continues, i think my subie knows i dont know how to work on her so shes making sure i know what im doing. Well so as i was on the course in my second lap i was pushing it hard, and when i was making hard left or right turns id head the horrible metal on metal noise. Then i went for the finish line i i heard this horrible metal on metal / clunkingish sound. This is the kicker, the car can still drive? i didn't drive it home, i just got a tow but it makes the god aweful noise when being moved, it also can go in to gear without an issue. my question is did i blow up my center diff? or rear diff? I've read you can lift it and put it on stands, and hold one wheel and what ever wheel you hold the others will kick on. Any ideas that be great. Also im almost positive i can pull the center diff out with out taking the trans off right? Thanks Jack
Re: Rally X then huge boom.... need help
Have you checked all the suspension and braking to make sure that's not the problem?
Is your car an auto or manual trans?
czei
Post by czei »
This should be something a mechanic could diagnose quickly. I'd check wheel bearings first, but who knows?
devilzdriver
Legacy777 wrote:Have you checked all the suspension and braking to make sure that's not the problem?
Suspension is brand new, at track had it on stands and checked brakes, did not check wheel bearings was not coming from wheels though only from the middle of the car.
northcoast
Post by northcoast »
Is the drive line rubbing on the rear dif guard? That makes a sound similar to what you're describing.
Lifted 91 LS Wagon : SOLD
87 GL-10 Turbo : SOLD
Lifted 97 Impreza OBS
98 Impreza OBS RallyX / DD
devilzdriver
please pardon my ignorance what would i be looking for? to me everything looks fine. I go under the car and twisted the drive shaft and it feels loose, like i can spin it a good couple inches before it feels like it grabs? any ideas gang?
Any chance you could take a couple pictures from under the car of the driveline where it inputs into the transmission and where it bolts to the rear diff?
devilzdriver
Legacy777 wrote:Any chance you could take a couple pictures from under the car of the driveline where it inputs into the transmission and where it bolts to the rear diff?
Well i just took out the driveshaft and trans x member the Rear tail section of the trans is toast, but when i drained the fluid no chunks or anything. But the output shaft was moving left to right in the tail section so i think i need a new one? ideas gang
It's probably the the rear transfer gear. You could try dropping just the rear section of the trans to see what exactly is dead, but I'd probably drop the trans, split the case and inspect everything.
devilzdriver
i cant get the rear section off because of these two darn snapped bolts the two bottom ones to be exact. And hawaii does not seem to sell EZ outs.... if it is the rear gear thats done, can i replace it? or is it easier to just buy a 04 WRX trans?
Is this going in a turbo or non-turbo Legacy?
IMO, it'd be better to get a new trans. However I think the 04 WRX trans is going to have a 1.1:1 gear reduction in the rear, so you'd either have to swap to the 3.545 rear diff or change the transfer gears in the rear. This is assuming you have a turbo Legacy. If you have a non-turbo Legacy, you'd have to swap to a hydraulic clutch setup with pedals and will likely be more of a pain in the butt.
devilzdriver
Legacy777 wrote:Is this going in a turbo or non-turbo Legacy?
I actually found a Impreza L 3.9 final drive AWD trans and i cleaned it and its going in tomorrow, i did alot of reading and the numbers on the trans tell me 3.9 and i have a 3.9 in the rear and it should just drop right in! yay!! also yes it is a Turbo leggy
Good deal! Glad you found a 3.9 FD trans.
devilzdriver
Legacy777 wrote:Good deal! Glad you found a 3.9 FD trans.
Yea for 250 i can't complain hawaii + carparts usually = XXXXX dollars lol
