fuel separator
fuel separator
where the hell is it located on a wagon? is it out of the car on the underside? cause i ripped apart the interior and can't find it...
93 Winestone TW project
Re: fuel separator
isn't that built into the fuel pump sending unit on the passenger side?
which is in the tank and why you could not find it
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Re: fuel separator
Assumed it was like the sedan one
Re: fuel separator
It is in the car on the passenger side, behind the wheel well. It'll be covered up. Here are some pictures of where it's at and what it looks like.
http://www.surrealmirage.com/subaru/images/swap/03
My site for whatever reason is REALLY slow, so be patient.
Re: fuel separator
Interesting coincidence...just came across this part on a project.
Besides the name, what does it do?
(And yes, Josh, your site is S-L-O-W today.)
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: fuel separator
What it does it keep fuel from being drawing into the evaporative emissions system in the event the fuel tank is filled too much. The two vapor/vent lines come from the tank and go into the bottom of the separator bottle, and then the single line going to the charcoal canister comes from the top of the separator bottle.
I'm going to have to submit a trouble ticket because my site is STILL slow today.
Re: fuel separator
BE CAREFULL that bracket is SHARP don't ask how I know lol
Re: fuel separator
My site should be running ok now....let me know if it's still slow.
Re: fuel separator
kk still need to pull my rear end apart but its too cold to pull trim... and no heat gun...
