turbo970's 92 tw rebuild with updates
Re: turbo970's 92 tw rebuild
its sad the subie dealer here has to order a crank pulley bolt lol
Lookin good!
thanks we are hoping to start it monday or tuesday
heres some more fallow up pix and pix of some goodies going on the wagon. its![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1350069195083.jpg)
![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1350069155612.jpg)
![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1350069178733.jpg)
![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1350069226900.jpg)
painting the tmic
thanks to you guys that have been helping with this rebuild. whether it was parts or info they were both needed
and ordered this today
![Image](http://i1018.photobucket.com/albums/af306/solow970/grimmspeed.jpg)
^^^^^^^ the heat shield made it here today grimmspeed have good turn around time and customer service
they said they have to mod the exhaust and the car will be ready to start. all this waiting lol
well the car starts and sounds real good. one more delay though. the tps is shot so they are going to have one by monday so i can finally pick up the subie. rather wait a lil longer than be broke down some where. the idle is way high and they said it shifted hard from 2nd to 3rd. they scanned it again and came back as a bad tps
boost gauge is in ![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1350832850303.jpg)
but look where they hooked it up at. will i need to relocate that line?
![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1350832864546.jpg)
Yes, it will need to be relocated. It should be tied into the intake manifold. The easiest and best spot to tee it into is on the passenger side intake runner where the stock MAP sensor gets its pressure from. Just use a vacuum tee fitting in that line.
Make sure to plug that hole in the intake elbow that they. I'm kind of surprised they did that....that's not right.
me too. i saw that and was like what the f**k. how is that going to read boost. i'll relocate it after i get the car back.
picked up my new tires. got a decent deal on them
![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1351034606477.jpg)
![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1351034621840.jpg)
car was suppost to be done tuesday. just told me today that the local napa lost my tps for my car. now gotta wait til next week
car is at my folks just cant drive it yet
![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1351650981795.jpg)
![Image](http://i1018.photobucket.com/albums/af306/solow970/ResizedImage_1351650995475.jpg)
subie still in the trans shop yet no word if he found anything. been there since nov. 17th
What the hell were they thinking with that boost line?????
well after a month in another shop he still has no clue why the subie isnt shifting right. i'm to the point of saying f**k it and part the damn thing out
Can you recap what you have all done, what the shops have checked, and specifically what it's doing...or lack of doing.
it shifts hard first threw 3rd and just wines up not engaging into 4th. fluid is clean and full. the trans shop said he's still checking things out
When was the last time it was working properly, and what work all has been done since that time it was working properly and now?
it worked when i test drove it. then after the motor was rebuilt and installed it stopped working
Well then I would think that it could be an issue with the motor or perhaps wiring harness, but unfortunately there are a lot of variables that it could be. I can certainly understand your frustration.
well i got 3 grand in a car i cant drive. every time i call the trans shop he says he hasnt looked at my car yet
That sucks! It seems like the shops are just passing it from one to another and don't want to deal with it. Are you paying them or are they supposed to be fixing their fuck up?
