http://bbs.legacycentral.org/viewtopic.php?t=14619
http://bbs.legacycentral.org/viewtopic.php?t=1441
Everything has been checked by my mechanic and the previous owner had this problem looked over by the dealership both had no clue.
I will try my best to describe it to you.
The problem only occurs once a day when the car is completly warm sometimes it will skip a few days with no apearance.
It starts with a little shimmy through the whole car almost allways in 3rd gear around 3000 rpm.
I can usually avoid the problem by accelerating to 4k or 5k rpm but if you let of the gas it starts to shake violently then I get thuding coming from the rear diff.
This is when I pull over for about 2 minutes then all signs are gone
car is completly normal after a 2 min break
This is how my problem differs from the other topics.
My thudding is so loud it can be heard from 15 to 20 feet away I know this cause I see people staring from bus stops and such.
My thudding is so jaring that it really feels like the rear end is hopping off the ground and draging.
This might offer insight
TODAY when it happened
I pulled over shut the car off put it in netural and tried to let it roll back But it would not.
I was on a steep hill and it would not budge, so I started rocking in my seat and it made a big thud and started rolling and kept thuding.
Then I stoped started it and drove off with no problems
One other thing when the problem occurs in snowy weather I lose all traction in the front end it's like I am driving on ice.
My big Q??? is what is causing my rear wheels to seize up like that.
Thanks for any info
