02/03 Tein springs on 93?
AlWaysDrivin
Post by AlWaysDrivin »
Found these in my area on CL. Wanted some clarification if they would be compatible with my 93 SS. After searchin around on here, from what I could tell, the 02/03 wrx springs and such can work on a 92-94. However, seeing as these are aftermarket, I was hoping someone could confirm or not that these could be usable for me?
http://portland.craigslist.org/wsc/pts/3520627399.html
Re: 02/03 Tein springs on 93?
I don't have an answer for you, but hopefully someone else can help.
subytech
Post by subytech »
I don't see why not. I'm running 04 STi struts with Tein coils so I've had to swap to the early 90-91 top hats in the rear due to the taper at the top of the STi spring but if you are running non STi struts and springs then you should be fine with whats in your car.
devilzdriver
Post by devilzdriver »
I had them on my leggy i had 03 wrx struts and Tein springs, be warned i blew 2 struts and its super stiff not really DD friendly....
dreadnok
Post by dreadnok »
I ran the Tein Type S springs on my 93 with no problems. They lower the car nice in the back but the front could have been lowered another 1in for my taste
