Cheap custom intake for stock or aftermarket turbos
Snorkus, filters, throttle bodies and intake manifolds.
Turbo_Carl
Post by Turbo_Carl »
Working on making a custom intake. I will share the entire build process with you as I did with my air to water intercooler setup. This should take far less time.
Considering using these parts
Couplers with vac ports.
http://www.siliconeintakes.com/product_ ... 106565ee03
Fittings
http://www.siliconeintakes.com/index.ph ... 106565ee03
Port system for BPV return option.
Thoughts, suggestions?
1993 SS. 5MT, STI Fuel Pump, Custom Intake, Diamond Coil Pack, Forge BOV, Hallman MBC, Custom AWIC, CNT 3" Downpipe, SLP Resonator, Carbon Muffler, TD04, FCD
1987 Ford T-Bird Turbo Coupe (Pikes Peak Hill Climb Car)
Turbo_Carl
Re: Cheap custom intake for stock or aftermarket turbos
Here's what I whipped up today. Will probably switch to T fittings for the final product, but you get the idea. All that for just under $100.
http://i49.tinypic.com/xejub4.jpg
http://i48.tinypic.com/pr5zd.jpg
More to come!
Turbo_Carl
pictures now attached lol
I changed the pics to links since they were a little large.
Do you plan to run that adapter for the BPV return?
Post by SILINC3R »
Pretty cool. I recently purchased some intake pipe from them and damn is it thick. Looks like .070. I could build an exhaust out of it haha.
Turbo_Carl
Legacy777 wrote:I changed the pics to links since they were a little large.
Yeah I plan on doing that for the final product. I didn't want to hold them up there as they were getting ready to close when I arrived. I will swing by another time this week, and include a video of the install when I put the TD04 on. Should be getting that back this week too. I could get lost in that place.
Everyone is so used to me coming in all the time they let me walk around wherever I want lol. It's not really meant to be a retail setting as they are an internet warehouse. Really good people though, I highly recommend giving them your business!
