rabbits ate through front wire loom (the one that hangs down behind radiator) I spliced/soldered all the wires except for the duplicates. I have yellow/with red stripe, green/with black stripe and black wires. I was wondering if these are all interchangeable? Or if I need to trace these wires back and look at a wire diagram to determine where they are coming from and where they need to go. Also I am having a hard time located such a diagram, so if anyone could help i would much appreciate it.
1991 legacy used to be NA auto, now is 5spd EJ20g
Front wire loom help EJ20G 91 legacy
Re: Front wire loom help EJ20G 91 legacy
So the chassis is a 91 legacy correct? If so, the 1990 wiring diagrams should be close or be the same.
http://www.main.experiencetherave.com/s ... agrams.zip
You're welcome.
