92ColoradoTurbo's build/help
Re: 92ColoradoTurbo's build/help
Black to black abd green to green only. Never mix them up. Green should be stored memore and black should be active. Read josh' instructions again based off the info i have given you. Should help shed some light on his instructions.
92ColoradoTurbo
Post by 92ColoradoTurbo »
Ok, so i drive and let it warm up (with all connectors disconnected). Turn car off. Connect green to green and black to black. Turn ignition to "On" position. Depress gas pedal, let go halfway and hold, then let go. Start engine. Drive till 4th gear. <-- that should erase codes?
Then to check current ones... unplug connectors, drive around, plug green connectors in, check codes? yeaa? lol
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
Yes, that's correct
92ColoradoTurbo
Ok, so when i depress the pedal and let go halfway, hold, then start car, this makes the cel go away while connectors are connected. But when i start driving, right when i shift to 3rd gear, the cel starts blinking (1/sec). and then when i disconnect, drive around, then plug black in to check codes.. it just blinks, no codes. What am i doing wrong?
Chris
You're not doing anything wrong. You've cleared the codes and a steady blinking CEL means there are no codes stored in the ECU.
92ColoradoTurbo
oh.. So should i drive all day tomorrow and then connect the green ones and see if anything comes up, just to make sure? or do you think i dont have at all?
Chris
92ColoradoTurbo
And when i have greens connected and ignition in "on" position, near my MAP was clicking and my fans were turning on and off with about 2sec intervals... What's this all about?
Chris
Thats the ecu cycling thru the sensors. That is normal.
92ColoradoTurbo
Got this for $300. 3in turbo-back exhaust with a divorced downpipe. Not too sure about the brands. The catback is the ebay SRS which i've heard good reviews. As for the downpipe, the guy said something about "BPM" and it was like austrailian spec... he said it was good and that he had it on his vf43 and loved it.
Anyways, time for some pics soo strap in!
Then I cleaned it up a bit...
And it'll be replacing this!
Chris
That exhaust is freaking awesome!!! Nice find bud!
92ColoradoTurbo
Ok, so I'm gunna attempt to pull the heads off soon to get em to a machine shop and get those exhaust valves fixed. Any tips or anything i should know before i have at it? I just take the intake mani off and all the accessories like alternator, a/c, resevoirs, etc., right? what about all the belts and tighteners off the front, do those have to come off?
Gunna try and get em off thrusday-sunday this week, think thats enough time?
anything will help, thanks!
EDIT: Do the valve covers AND camshafts come off with the heads altogether?
Chris
On Single cam heads you can pull them without taking the valve covers off. You do have to remove the cam gears and the lower left t belt pulley to remove the back timing covers. there's also a 10mm bolt that is on the drivers side head for the oil dipstick, and i "think" there's a 10mm bolt on top for the water lines. Pull the motor. If you're taking the heads in to get head work, take the cams off and pull the lifters or rocker assembly, it'll make it easier for the machinist.
92ColoradoTurbo
cj91legss wrote:Pull the motor. If you're taking the heads in to get head work, take the cams off and pull the lifters or rocker assembly, it'll make it easier for the machinist.
Whoa... I thought I didn't have to pull the engine out to get the heads off.
And I'll remove the cams and rockers so i just send in head with the valves and valve springs in?
Is shooting for a goal of "having this all back together and running by the end of next month" a plausible goal for a first timer? lol
Chris
Have you downloaded the factory service manual from me? If not, do that and read through the procedure on pulling the heads. It gives you pretty detailed info.
http://www.main.experiencetherave.com/s ... and_Elect/
92ColoradoTurbo
Yea, ive got that download! and it's pretty awesome cause i'm very visual lol
I guess one of my bigger questions (the most nerve-racking) is removing the cams from the heads. When i put em back in, I have to oil with engine oil but is there a certain way to put em in for like alignment? or do i just put em in the head and they'll do their thing?
Chris
Cant fully remember about sohc cams but the dohc cams have a lip that sits in a groove on the head so they cant go in wrong (unless you put the wrong cam on the wrong side) the cams are marked too.
Use engine assmbly lube on all surfaces that contact eachother. You dont have to use a whole bunch on each spot. Just a nice thin coat on the cam bearing surfaces and the cam lobes..
You can't put the cams in wrong. One is longer than the other.
And yes, use assembly lube....not oil.
macipusy
Post by macipusy »
Arrghhh....the HeuBerger sticker is hurting my eyes....I hate free advertising for stealerships, especially Shortline Subaru who used to rivet their badge on.
Off with it unless you work there or they are paying you for advertising space!!!
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
DD50
Post by DD50 »
macipusy wrote:Arrghhh....the HeuBerger sticker is hurting my eyes....I hate free advertising for stealerships, especially Shortline Subaru who used to rivet their badge on.
My car originally came from Shortline. I wish those bastards didn't rivet their badges on. I can't stand the fact that it's still on my car and if I take it off it'll look really stupid
Proud Owner of a 1992 Winestone Mica Subaru Legacy LSi non turbo with 198,000 miles. Soon to be turboed
If I ever buy a new car, I will tell the dealer, if you put your badge on my car I won't take it.
92ColoradoTurbo
So after about 3 days of working on this (mostly by myself), I've finally gotten the heads off! no fur sum piks!
Hehehehehehe
Cause everybody does this picture... Zero shaft play on the 180k VF11 and my TD04 :)
Driver side head (2 & 4)
Passenger side head (1 & 3)
And off with the sticker!
Chris
92ColoradoTurbo
And now the heads are disassembled enough for the machine shop. Can i drain the oil in the left one?
Chris
Yes you can drain the oil out of the left one.
Looks like you'll be needing a new passenger head. that #1 cylinder exhaust valve doesn't look so good.
alexandermf
Post by alexandermf »
Getting that hideous hueberger off was more pita than all the other work :P
The exhaust looks dope, can't wait till its ALL on
92ColoradoTurbo
Quick question! Where do these go?... I think they fell off from my intake mani when i was taking the fuel rails off of it. (there are four of them)
Chris
