wtb in nj: legacy ss brake master cyl and prob valve
So as the title states I need the brake master cyl and brake prop valve from a legacy turbo ss
Needs to be 4 wheel disc non abs units. In your in nj, nyc area ny, or philly area pa, I will pick up. I have cash in hand and need these asap to get my car running again....if anyone knows a part number for the master cyl that would help as well as an alternative. But still would need a prop valve
Re: wtb in nj: legacy ss brake master cyl and prob valve
All SS master cyls are abs from what i understand, get a 93-4 SVX fwd non abs master cyl. 220 at the stealership, could noy find one used
93 Winestone TW project
Dammit! Lol the guys on rs25.com have wrong info then, they say they come non abs, at least some of them. Been scouring everywhere for one from an svx too.
gimme a sec, i'll get the box from mine w/ a P/N for you. again, 220 from the stealership and mine was actually shipped from jersey and they had 4 left I was told
Awesome thanks alot dude
p/n is 26410PA001 FHI # lol
i'm in the process of upgrading my brakes and the M/C is garbage so I said "Why the Hell Not?" lol
sorry I didnt get that to u in time to call ur dealership...
dude, you're the man. I took that part number to subarugenuineparts.com (they're based in washington state)and plugged it in. it found it in the system. I called just to confirm it was correct, the guy said yes. I ordered it. and it was $161+ shipping of $17!Someperson wrote:sorry I didnt get that to u in time to call ur dealership...
now i just need a 4wheel disc non abs brake prop valve, might get the one from japanparts.com
glad I could help, and did you know it's 1 1/16 bore so you can run Brembos on it?
I did know its 1 1/16th bore but didnt know thats what I needed for 4pot brembos lol I dont think ill be getting those but it is good to know!
biggest bore subaru makes
I was running 4 pot wilwoods and they worked great, I just swapped them over to my forester and even better braking as the foz is lighter
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
I actually have a 96 impreza wagon ej20g swapped
