WTB Pull style turbo transmission
As the title states, I NEED ONE SOON
Should be coming up on some cash this weekend. Anyone wanna shoot me what they have?
Gear ratio doesn't matter to this point i'll source a diff/axles if I have to, I just need the damn car fixed.
SO just so everyone knows and is clear, I AM WINDOW SHOPPING!
Seeing as I have ran thru SS 5MT 3.90 Transmissions like underwear, I'm probably not interested in paying too much for one, but I will consider that an option.
northcoast
Re: WTB Pull style turbo transmission
Post by northcoast »
What's the difference between the push and pull?
Lifted 91 LS Wagon : SOLD
87 GL-10 Turbo : SOLD
Lifted 97 Impreza OBS
98 Impreza OBS RallyX / DD
Pull style has a ring inside the clutch fingers that the bearing snaps into place similar to the ring inside a diff that snaps onto the axle stubs to hold them in place only bigger. The fork pulls on the bearing which pulls on the clutch fingers to relieve pressure on the clutch disk.
Push style pushes on the fingers to relieve pressure on the clutch disk.
91-94 turbo legacy, jdm wrx 93-2004, and 04-present sti ibelieve is pull style hydrolic clutch style.
