Where does this go/do?
Snorkus, filters, throttle bodies and intake manifolds.
94Turbro
Post by 94Turbro »
Ive done a fair bit of searching but i just cant find what im looking for, can anybody please tell me what this part is and where the vacuum hoses on it should go?
1994 Legacy SS: TD04, FMIC, Daily baby hauler/ Hoon cart.
martimus919
Re: Where does this go/do?
Post by martimus919 »
That's the Idle Air Control Valve (IAC) and it goes right next to the throttle body on the intake manifold.
The large vacuum line goes directly into your intake and the two lines on the bottom are for coolant that go from you coolant cross over pipe into the IAC then out into your throttle body.
Essentially without this part your car won't idle.
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
94Turbro
Post by 94Turbro »
Seeing as my major vacuum lines are all connected as one(idiot previous owner), Block Breather, Heads, IAC, etc. could that be why my car is idling aroung 1500-2000rpm?
92ColoradoTurbo
Post by 92ColoradoTurbo »
Woo another guy from Colorado! Check out the Colorado Cruise thing going on in the community section :D
Anyways, take a look at these pics, might help..
http://bbs.legacycentral.org/viewtopic.php?f=1&t=51561
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
94Turbro
Post by 94Turbro »
I actually just looked at that thread for help haha. ive been surprised at the number of T-leggy owners ive seen from Colorado on here
CAV3MAN227
Post by CAV3MAN227 »
^yea I know quite a few.
-Joe
alexandermf
Post by alexandermf »
You in dtown or the springs? Or up in those big pointy things off to the west?
94Turbro
Post by 94Turbro »
Aurora, so technically D-townish haha
