Wanted turbo pcv breather lines
I'm looking for some breather lines that are cracked on on my 2.2 turbo I need numbers 12, 9 and 4 on the diagram thanks
Re: Wanted turbo pcv breather lines
12 is no biggie to find used since it's plastic, but 9 & 4 are rubber, and I'd highly recommend buying new, unless someone has new or nearly new (since at this stage the rubber lines will be as hard as plastic and likely crack as soon as you try to fit them)
4, I just went to the local parts store and asked for a small piece of hose, they might want to sell you a hole foot unless you know them well.
Charles
Yea will most likely do that for the rubber. mainly want the plastic one I can get it from the dealer it's like $30 bucks just seeing if any one has a good uses one if not no big deal
I have the plastic one I too would get new hose for the rest
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
What do you want for the plastic one shipped 95828 thanksdiesel devil wrote:I have the plastic one I too would get new hose for the rest
$25 shipped
Ill take it pm sent
