I then cleaned the engine bay and ended up getting water in my cylinders, so I dried those out and after many attempts of getting it started it finally started right up.
Now what it is doing is while it is running, it is dumping fuel into the cylinders which is causing it to smell of raw fuel out of the exhaust. Thankfully this is not my DD yet.
So I thought it might be the injectors, so I go to take two of the injectors out and when i take them out I see fuel dumping from the fuel rail into the cylinder. So then I run to the fuel pump and unplug it and by this time I ended up getting two cylinders full of fuel to the point the car wont even turn over(I only tried twice).
So Im stuck. Ive read it could be the Fuel Pressure Regulator, but I took the breather hose off of it and there was no gas leaking out. Im very confused.
There is also zero gas in my oil which is good.
Any thoughts or opinions on what it could be?
