Later is NOW!
Couple people already knew But here's the official update. I went Pre Facelift. BAM!
I have been wanting to do this for a LOOOOOOONG time. Finally did it. If anyone has the hoodscoop splitter for an 1991 SS, I NEED IT ASAP.
OK, Fender and Core suppoirt fitting
Got the donor hood and headlights test fitted
I want to make sure my intercooler is "level." Start with the ground surface
Then check all connections to make sure the IC will be level.
Still A little off but tat will be changed later
And now to the side markers, I want to still keep the 92-4 side markers, but they will be signal indicators in this application.
First you have to oval out the hole towards the front end like so
Then you insert the side marker/fender trim like so and make an outline with a straight pick
Here you have your diagram
Then you take a dremel and a cutting wheel, A 24-36" wand is MOST useful here, and cut away at your marks
After everyting is all cut out and you have your side marker trim and side markers installed this is the end result.
I wired my sidemarkers up to be Blinkers because that's how I want it
I had to cut away alot of bumper skin to fit my fmic, Also had to cut away the mounts for the 91 SS turn signals, BUT that's ok because I have some JDM stuff on the way.
FMIC somewhat centered
End result, Keep in mind it still looks like shit. I need to buy a 1991 Bumper beam and a 1991 hood latch. All the small shit will be worked out after i have the rest of the parts and can fit everything else sung.
I'm so excited about this. The whole car will start undergoing sanding and prep for paint in a couple weeks.
There's my surprise.
