Subaru Manuals, Service Bulletins, and more
FAQs, community and board information.
UPDATE: 1/2/2020
I am in the process of upgrading my server and in doing so have discovered some issues with filenames that contain symbol ampersand "&". So I have had to rename anything with an ampersand in it to and. So if you happen to get a server error while trying to access anything, please replace the '&' with the word 'and' (remove quote marks). I will try and review the server logs and update links that refer to the old files. I tried to setup an automatic redirection, but wasn't able to do that.
Thanks for everyone's understanding
Well....I wouldn't want you guys to think I don't like you and not get you a Christmas present.....so I'm going to inundate you with info.
Larry posted a link over on the BC-BF List for these parts & service manuals. This guy apparently scanned them in because he used an EJ22 motor in his airplane. Well the scans were a little hard to navigate....so being me, I added bookmarks to the pdfs so you have a nice index structure to see what's all in the pdf. The FSM & Parts manuals only include the engine/electrical pages, but contain most of the important stuff.
Please right click and save the pdf's. Thanks!
Note: I've updated all the files so the bookmark index shows up automatically. If you're not sure what I'm talking about, and can d/l again, you'll see what I mean.
Here is the root link for all the service manuals
https://www.main.experiencetherave.com/ ... ual_scans/
1992 FSM (Engine & Electrical)
https://www.main.experiencetherave.com/ ... and_Elect/
Note: I added a scan related to the combination meter that wasn't previously in there. 9/9/2012
1992 Liberty FSM (FULL) (Overseas Legacy/Liberty manual) NEW
https://www.main.experiencetherave.com/ ... SM_-_FULL/
1990-1994 Parts Manual (Engine)
https://www.main.experiencetherave.com/ ... _-_Engine/
1992 Service Bulletins
https://www.main.experiencetherave.com/ ... Bulletins/
Multi Year Subaru Service Bulletins
1990-1994 Legacy Parts Catalog - FULL
viewtopic.php?t=30531
Don't forget the other scans I already have there.
Also, some of you know this, but I have scanned my entire owner's manual as well.
You can look at each page or d/l a complete pdf file
https://www.main.experiencetherave.com/owner/
Spooled Up Racing FSM Collection
http://www.spooledupracing.com/download/Manuals/FSM/
Collection of 2005-2009 Legacy FSM's
http://people.csail.mit.edu/ilh/vacation/
A collection of A LOT of Subaru manuals; hats off goes to the folks over at sl-i
http://sl-i.net/FORUM/viewtopic.php?f=14&t=28539
Like I said, there's A LOT of info in these pdf's. The service bulletins have a lot of good info too.
Enjoy
NOTE: Please do not use file downloader programs to leach all the files from my server. It causes excessive traffic and slows connection speeds for everyone, including me. I reserve the right to terminate and/or ban IP addresses if I see excessive repeated connections.
Thanks for understanding.
mTk
no title
Post by mTk »
Thanks!
MK
1992 BC672 AWD 5MT
Wow! Thank you so much! This is awesome.
Now for the index of everything
Code: Select all
1990-1994 Subaru Legacy Parts Manual – Engine
*  Illustrated Index
*  Group Index
*  Short Block Engine
*  Gasket & Seal Kit (Engine)
*  Cylinder Block
*  Timing Hole Plug & Transmission Bolt
*  Cylinder Head
*  Piston & Crankshaft
*  Flywheel
*  Camshaft & Cambelt
*  Valve & Valve Rocker
*  Rocker Cover & Oil Filler Duct
*  Timing Belt Cover (To Dec ’92)
*  Timing Belt Cover (From Jan ’93)
*  Oil Pan
*  Oil Pump & Oil Filter
*  Oil Cooler; Turbo (‘91MY)
*  Water Pump; NA
*  Water Pump; Turbo
*  Turbo Charger System
*  Intake Manifold; NA (’90 & ‘91MYS)
*  Intake Manifold; NA (’92 & ‘94MYS)
*  Intake Manifold; Turbo
*  Air Cleaner
*  Air Duct
*  Fuel Pipe System
*  Fuel Injector
*  Engine Cooling System; NA
*  Engine Cooling System; Turbo
*  Throttle Body & Air Duct
*  Alternator Bracket & V Belt
*  Spark Plug & High Tension Cord
*  Wiring Harness-Engine; NA
*  Wiring Harness-Engine; Turbo
*  Starter (1) MT (1.0KW)
*  Starter (2) AT (1.4KW)
*  Alternator
*  Hose & Clamp (P.C.V.); NA
*  Hose & Clamp (P.C.V.); Turbo
*  Emission Cont System; Turbo
*  Engine Electrical Parts
Code: Select all
*  Table of Contents
*  1-1 Specifications
*  2 Engine Section Index
*  2-1 Emission Control System and Vacuum Fitting
*      System Application
*      Schematic Drawing
*      General Precautions
*      Crankcase Emission Control System
*      Ignition Control System
*      Evaporative Emission Control System
*      Vacuum Fitting
*  2-2 On-Car Services
*      Foreword
*      Engine Compression
*      Intake Manifold Vacuum
*      Hydraulic Lash Adjuster
*      Fuel Injector
*      Oxygen (O2) Sensor
*  2-3 Engine
*      Mechanism and Function
*            General
*            Timing Belt
*            Belt Tension Adjuster
*            Belt Cover
*            Valve Rocker ASSY
*            Cam Shaft
*            Cylinder Head
*            Cylinder Block
*            Crankshaft
*            Piston
*      Specifications and Service Data
*            Specifications
*            Service Data
*      Component Parts
*            Timing Belt
*            Cylinder Head and Camshaft
*            Cylinder Head and Valve ASSY
*            Cylinder Block
*            Crankshaft and Piston
*      Service Procedure
*            Timing Belt
*            Valve Rocker ASSY
*            Camshaft
*            Cylinder Head
*            Cylinder Block
*      Troubleshooting
*            Engine Trouble in General
*            Engine Noise
*  2-4 Engine Lubrication System
*            General
*            Lubrication Lines
*            Oil Pump
*            Oil Filter
*            Oil Pan & Oil Strainer
*            Oil Pressure Switch
*      Component Parts
*            Oil Pump
*      Service Procedure
*            Oil Pump
*      Troubleshooting
*  2-5 Engine Cooling System
*            General
*            Cooling Lines
*            Water Pump
*            Mechanical Seal
*            Thermostat
*            Coolant Filler Tank
*            Specifications
*            Service Data
*      Component Parts
*            Water Pump
*            Radiator and Radiator Fan
*            Water Pipe
*      Service Procedure
*            Water Pump
*            Thermostat
*            Radiator
*            Radiator Cap (Filler Tank Cap on Turbo Model)
*            Radiator Fan and Fan Motor
*      Troubleshooting
*  2-7 Fuel Injection System
*            General
*            Air Line
*            Fuel Line
*            Sensor and Switch
*            Control System
*            Self-diagnosis System
*            Turbocharger System
*      Component Parts
*            Intake Manifold
*            Air Intake Duct and Throttle Body
*            Air Cleaner
*            Turbocharger Unit
*      Service Procedure
*      Troubleshooting
*            Supplemental Restraint System “Airbag”
*            Precautions
*            Pre-inspection
*            Troubleshooting Chart for Self-diagnosis System
*            Output Modes of Select Monitor
*            Control Unit I/O Signal
*            Troubleshooting for Engine Starting Failure
*            Troubleshooting Chart with Trouble Code
*            Troubleshooting Chart with Select Monitor
*            General Troubleshooting Table
*  2-8 Fuel System
*            Fuel Lines
*  6-1 Engine Electrical System
*      Component Parts
*            Starter
*            Alternator
*      Service Procedure
*            Starter
*            Alternator
*            Spark Plug
*            Ignition Coil
*            Spark Plug Cord
*      Troubleshooting
*            Starter
*            Alternator
*  6-2 Body Electrical System
*      Engine Electrical (MPFI)
*      Radiator Fan
*      Lighting
*      Cruise Control
*  6-3 Wiring Diagram and Troubleshooting
*      General Description
*      Working Precautions
*      How to Use Wiring Diagram
*      How to Use Super Multiple  Junctions (S.M.J.)
*      Wiring Diagram and Troubleshooting
*            Power Supply Routing
*            Charging
*            Starting
*            Engine Electrical
*            Radiator Fan
*            Lighting (Headlight)
*            Lighting (Tail, Illumination, etc.)
*            Room Light and Door Switch
*            Stop Light
*            Turn Signal and Hazard
*            Trunk Room Light
*            Back-up Light
*            A/T Control
*            A/T Shift Lock
*      Electrical Unit Location
*  Compressor Map – IHI BRL4016 (EJ22 Turbo)
Code: Select all
1992 Subaru Service Bulletins
*  2.2L 4-Cyl & 2.2L 4-Cyl Turbo – VIN (6)
*      Removal & Installation
*      Overhaul
*      Engine Oiling
*      Water Pump R & I
*      Torque Specifications
*      Engine Specifications
*  Interference Verification Check for OHC Engine
*  Specifications
*      Capacities
*      Quick-Service
*      Mechanical Checks
*      Ignition System
*      Fuel System
*  Theory/Operation
*      Air Induction System
*      Computerized Engine Controls
*      Fuel System (Carbureted)
*      Fuel System (Fuel Injected)
*      Ignition Systems
*      Emission Systems
*      Self-Diagnostics
*  Basic Testing
*      Fuel System
*      Ignition Checks
*      Idle Speed & Ignition Timing
*      Fuel Pump Circuit Tests
*  Tests W/Codes
*      Self-Diagnostic System
*      Diagnostic Code Charts
*      Read Memory Mode
*      D-Check Mode
*      Clear Memory Mode
*      Crank Angle Sensor
*      Starter Switch
*      Cam Angle Sensor
*      Fuel Injectors
*      Coolant (Water) Temperature Sensor
*      Knock Sensor
*      Airflow Meter Circuit
*      By-pass Air Control Valve
*      Throttle Position Sensor
*      Vehicle Speed Sensor No. 2
*      Canister Purge Control (CPC) Solenoid Valve
*      Air/Fuel Ratio Control System
*      Idle Switch
*      Wastegate Control Duty Solenoid Valve (Turbo)
*      Pressure Sensor Duty Solenoid
*      Atmospheric Pressure Sensor (Non-Turbo)
*      Airflow Sensor
*      Neutral Safety Switch (Man. Trans.)
*      Inhibitor Switch (Auto. Trans.)
*      Parking Brake Switch (Auto. Trans.)
*  Tests W/O Codes
*      Symptom Diagnosis (Carbureted – Justy)
*      Justy Symptom Diagnostic Chart
*      Loyale Symptom Diagnostic Chart
*      Legacy Symptom Diagnostic Chart
*      SVX Symptom Diagnostic Chart
*      Intermittent Problem Diagnosis
*  Wiring Diagrams
*      Wiring Diagram (Legacy 2.2L PFI & Turbo)
*      Component Location Menu
*      Engine Compartment, Headlights (Grid 1-3)
*      MPFI Control Unit (Non Turbo), Ignition Relay (Grid 4-7)
*      Check Connector, Ignition Coil (Non Turbo) (Grid 8-11)
*      MPFI Control Unit (Turbo) (Grid 12-15)
*      Check Connector, Ignition Coil (Turbo) (Grid 16-19)
*      Fuse Relay Box, Ignition Switch (Grid 20-23)
*      A/T Control Unit, Shift Lock Control Unit (Grid 24-27)
*      ABS Control Unit, Cruise Control Unit (Grid 28-31)
*      Air Suspension Sensors, Height Control Unit (Grid 32-35)
*      A/C Relay Box, Air Bag Control Unit (Grid 36-39)
*      Front Wiper Motor, Hazard Sw (Grid 40-43)
*      Instrument Cluster, Dome Light (Grid 44-47)
*      Auto Shoulder Belt Control Unit, Pwr Windows (Grid 48-51)
*      Power Mirror/Sunroof Sw, Tail Lights (Grid 52-55)
*  Electrical Component Locator
*      Buzzers, Relays, & Timers
*      Circuit Protection Devices
*      Control Units
*      Motors
*      Sending Units & Sensors
*      Solenoids & Solenoid Valves
*      Switches
*      Miscellaneous
*  Trouble Code 13 – Crank Angle Sensor
*  Vacuum Diagrams
*  Remove/Install/Overhaul – Turbocharger (Legacy)
*  Effects of Incorrect Fuel Use:  New Procedure
*  Incorrect Oil Pump Cover Torque:  New Specification
*  Fuel Injector Replacement
*  Incorrect Duty/ID/Data Charts:  New Charts
*      Updated Line Pressure Duty Diagram (1990 Legacy)
*      Updated Line Pressure Duty Diagram (1991-92 Legacy)
*      Updated Line Pressure Duty Diagram (1992 SVX)
*      Updated Cartridge I.D. Chart for Select Monitor
*      Updated A/T Data Ranges (1990 Legacy)
*      Updated A/T Data Ranges (1991-92 Legacy)
*  Low RVP Fuel Effects:  New A/T ECU-ROM Installation
*  Omitted Fuel Gauge Delay Amplifier:  Not Used in USA
Awesome!! This is going to be so helpful with the kitchen motor to find all the parts I need to get and replace.
bazhalliwell
manuals
Post by bazhalliwell »
i want to take the time to say thanks, i had my hard drive blow up 9 months ago and i lost all the info i had, even the book mark to this site i have just found it and now i have all this information to my legacy it is a good new year 4 me thnks :D
Barry Halliwell
welcome :)
JasonGrahn
Post by JasonGrahn »
yeah, i'm an ass. I didn't get you guys jack shit. I'm that jerky brother who simply says merry christmas. :P
-Jason Grahn
It's alright....you let me laugh at your brother getting drunk :lol:
JasonGrahn
Legacy777 wrote:It's alright....you let me laugh at your brother getting drunk :lol:
yeah, how often does one see a 15 year old beer bong guiness?
-Jason Grahn
hahahaha....no shit.
donquijote
Subaru service manual
Post by donquijote »
I have 1994 RHD Subaru Legacy L station wagon!
I checked out the service manual and it did not have the section that I was hoping to find. Would it be too much trouble for you if I ask you to scan a few pages in how to replace the transmission filter along with the detailed diagram of what each components are inside the transmission fluid pan? That would be greatly appreciated!
I have dropped the pan in an attempt to replace the transmission filter and the gasket. I removed all of the filter bolts inside, but it did not seem to have enough clearance to remove the filter due to a metal tubing right below the filter. If I know for sure what this metal tubing is for and if I can apply enough force to get the filter out, I will try to do it, but I hate to cause any damage to the metal tube.
My question is whether there is a peculiar way of extracting the transmission filter? If so, how is it to be done?
I really want to replace the filter, but if it is not meant to be replaced, I just might have to install a new gasket and put'em all back together!
Thanks for your time!
The screen in the trans is really not a filter....it's just a screen. When i took mine out...you had to remove the crossbar....and just need to give it a little force.
If you want....you'd be better off replacing the add-on filter kit near the battery.
Part # for the kit is in the part # thread.
donquijote
Thanks for the info!
Do most Japanese cars have this kind of crossbar nearby the filter, or is this something special to Subaru?
At any rate, since I wasn't sure of what this crossbar was for and I could not take the filter out, I decided not to mess it further and put'em all back to gether with a new gasket yesterday morning.
I will look into the add-on filter kit and it seems to be a much better option!
Thanks!
John
Not sure whether all japanese cars have this crossbar or not. It may be particular to the 4EAT tranny, which is used in other cars as well.
I've added some more goodies.....check 'em out ;)
Again Please right click and save as.
http://www.main.experiencetherave.com:8 ... nual_scans
1980_Subaru_Manuals
1990_Legacy_FSM_Supplement
1990_Legacy_Owner_Manual_Scans
1990-1994_Legacy_Parts_Manual_-_Engine
1992_FSM_(Engine_&_Electrical)
1992_Subaru_Service_Bulletins
1999_Legacy_FSM
2000+_Legacy_FSM
2002_WRX_FSM
2004_Impreza_WRX_STi_Factory_Service_Manual
Chiltons
FSM_Scans
Technicians_Reference_Booklets
You da man, Josh.
Had some issues with the pdf's not opening in an IE window. I've got everything fixed now.
THAWA
Post by THAWA »
yummy :)
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
shockman
Post by shockman »
Hey Josh,
great site mate! Very cool with lots of interesting goodies!!
Just wondering if you have or can get a Service Manual for a 94 Model JDM GT Legacy Wagon, its a BG5A? I have looked absoulutly everwhere! :roll:
Sorry, but no I don't have any JDM manual stuff.
I would think most of the stuff would be similar to the US 95 legacies, minus the motor & some of the wiring.
You could maybe try to find someone in japan.
TSiHawaii
Thanks for the great stuff
Post by TSiHawaii »
I really appreciate all that you did. This is great stuff.
snowjob
Post by snowjob »
I almost Sh*t myself when I saw this
http://www.driftquebec.com/legacy/1992_legacy.pdf
It's for the Liberty crowd, but their is still a lot of useful Info Here., and I'm not sure if anyone here has pointed it out, but I'm voting this become a sticky.
I shall now be know as the king :twisted:
Enjoy
Frazer
04 modified XT
99 LGT Limited
jasinwa
Post by jasinwa »
Is it just me or is the site down? I am getting only failures on each link I try...even the root is dead.
Post by entirelyturbo »
The links work fine for me, but I think Josh has the root site locked so only he can see it.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
