Cylinder Head Question
pnw13black
Post by pnw13black »
I was curious if there is any difference between the legacy as cylinder heads and the na heads apart from the oil coolant ports for the turbo and the cams. Any help is great!!
92 n/a leggy
5 speed swap
ACT Pro Lite flywheel
2.5rs Clutch
H&R Springs
Delta 220 cams
Second cat delete
Wrx wheels
RIP- Frankenmotor 2.5 :(
PhyrraM
Re: Cylinder Head Question
Post by PhyrraM »
IIRC, the exhaust valve is smaller on the turbo heads.
Turbo specific cams
I've heard the same comment on the valve sizes, but haven't been able to confirm myself, and yes the cams are different.
