EJ20 twin turbo
EJ20 twin turbo
http://cosprings.craigslist.org/pts/3720475764.html
One of these engines made its way to Colorado Springs. Wish I had a right hand drive Legacy..........1500 bucks. Not sure if that's good or not. Think it is since the transmission is with it
Proud Owner of a 1992 Winestone Mica Subaru Legacy LSi non turbo with 198,000 miles. Soon to be turboed
Re: EJ20 twin turbo
I saw it this morning and thought u could prolly offer a grand cash and make out with a great deal!
Re: EJ20 twin turbo
Not too bad of a deal since it includes a tranny. Too bad you throw 95% of what's bolted to the engine in the trash
Re: EJ20 twin turbo
I used most of my tt stuff on my swap and sold the rest. Bought an engine from jake for 400 no injectors. Sold the shortblock for 200 and the tt turbos and exhaust mani for 100.
Re: EJ20 twin turbo
Really? I couldn't find a buyer for my twin turbos. Found a guy who wanted one turbo but I said no. Still have the twins and the twin turbo header and up pipes. $1,500 is too much. Maybe $1,000...maybe. only because of the trans really. The shortblock and heads is mostly what you'd keep and then you have to buy a bunch of gaskets and source other parts and/or customize parts to fit like the throttle body so its not worth it imo. Been there, did that.
Re: EJ20 twin turbo
Itd be perfect for a postal wagon...
Re: EJ20 twin turbo
If you can find the tt crossmember, yes it would be perfect.
Re: EJ20 twin turbo
I must have came across deals then Kimo.
Re: EJ20 twin turbo
If I had the money I'd buy it for the hell of it. But I'm broke. I can only afford my non turbo LSi for now. lol
Re: EJ20 twin turbo
Yeah 1000 would be a good deal. The ej20R has a 9:1 compression ratio, and basically the same heads as ej20k WRX, but with STI cams. Rob should be able to modify his stock tune to accomidate the higher compression, but I'd ask him first if thats the direction you want to go.
Re: EJ20 twin turbo
I need some 20R heads then...
Re: EJ20 twin turbo
I have about x10 jdm legacy B4 twin turbos for breaking.
99-03 rev c and rev d.
Based in Ireland though.
Re: EJ20 twin turbo
You could probably make some decent money off of us if you parted them out.
Re: EJ20 twin turbo
Yes all for parting.
Anything you need. Every part can ask i would have
Re: EJ20 twin turbo
I would probably want some 20R phase 1 heads
