had to drill apart my shift linkage... help...
Someperson
as the title states, i had to DESTROY my linkage to remove my trans, anyone have a spare they're selling? or p/#s? i'll be back w/ pics lol
93 Winestone TW project
Someperson
Re: had to drill apart my shift linkage... help...
shitty iphone is shitty
u have to take that dual pin out before u can remove the u-joint.
u can get a whole new joint with new bushings for about 60ish from the dealer.
Someperson
i know, i was gonna see what i could scrounge on NASIOC... i've dropped 3 transmissions so far and that u joint has been a fuck every time... and my whole shifter is rusted as a bastard.... thinking possible 02 wrx shifter?
A good upgrade is a '02-'07 WRX shifter. It's both newer and has better bushings. To use the newer shifter you will also need the part from the shift rod that is held on by the roll pin from the WRX. It's only about $40 new, or you can pick one up used from Nasioc.
Someperson
anyone wanna help me pinpoint one? i need one like yesterday... moving in a month and need this running ASAP! i have the same name on nasioc
i used a wrx shifter and a new u-joint on my 93ss. nice and crispy.
soon ill be 6sp thou...hehe.
Someperson
lolnice
Someperson
Can i use my old rod and just pin the new knuckle and all of the downstream components on?
Are you talking about the shifter linkage? The linkage and joint need to match. So if you're using the new joint, you need the new linkage.
Someperson
And rod as well?
I probably have the whole shift linkage assembly with knuckle. If you want it, make me an offer. cheap is fine. Shipping will probably be about 10 bucks too so include that..
Someperson
40? Can do 50 inc shipping possibly
50 shipped and paypal'd sounds like a good enough number. Here's a pic just so you see what you are getting. it is all turbo legacy but everything you need it here.
Someperson
How are the bushings in the u joint?
Someperson
And if that's just the SS setup all i need is the u joint and bolts
