Clutch pin plug
Clutch pin plug
I need one, had to drill mine out... Anyone know the P/N, have a spare, or know where to get one?
93 Winestone TW project
Re: Clutch pin plug
The big hex bolt? Just so happen to have one of those too... Is there anything else you need?
Re: Clutch pin plug
Aww shit! Hmm... Those rubber pieces on the 5mt mount that keep it from rotating? How much for the plug overnighted? I'd like to pay <=10 for it + shipping
Re: Clutch pin plug
after the last shipping experience, I have no idea how much overnight would be lol. What rubber pieces?
Re: Clutch pin plug
Hmmm lemme see if i have a pic, the squares on either side of the trans where the mount almost wraps around the trans, 2 little neoprene squares
Re: Clutch pin plug
And How did you have to drill yours out? You just couldn't get it to break loose? Often times you'll need the correct size allen socket and a breaker bar if it hasn't been loosened in awhile. When i do trans swaps or clutches on my car i torque it down pretty good, but also put some antisieze on the threads unless grease gets on them when inserting the clutch fork pin.
Yeah find a pic, I'm still uncertain of what you're talking about.
Re: Clutch pin plug
Was stripped when i bought the car... And i can grab the mounts later just need that plug lol
Re: Clutch pin plug
Well since the plug is probably half the weight/size i would imagine shipping overnight would be about 20?
Re: Clutch pin plug
Do it
Re: Clutch pin plug
Paypal it. Ill send it out in the a.m.
Re: Clutch pin plug
K, u got the info on the last package? Not here yet
Re: Clutch pin plug
Is it the same on the wrx? Cause it's only $10 from the stealership...
Re: Clutch pin plug
Should be there today.9505 5104 8294 3098 3558 81
Re: Clutch pin plug
Found it
Re: Clutch pin plug
Was hidden in flyers
Re: Clutch pin plug
I hate ads in my mail box.......
Re: Clutch pin plug
Yep...
Re: Clutch pin plug
It probably is the same as wrx
