Okay, I was on the freeway in Portland Heading to pick up my girl friend from work.
All of a sudden the car wouldnt hardly idle, could hardly take off on flat ground, when I finally took off it was shuddering super bad when ever I tried to speed up.
Since then, ive changed the plugs, wires, fuel lines, fuel filter, coil, and maf. Fuel pump is good aswell.
Any ideas? Im out...
Help! Bad Idle
Subi-swap94
Help! Bad Idle
Current Cars
'94 Legacy SS - EJ20G VF22, 5MT
'70 Ford Maverick - 302 small block, C6 AT
Re: Help! Bad Idle
Have you checked codes?
Charles
Subi-swap94
Re: Help! Bad Idle
As in check engine lights?
if so there are none...
Also, its an ej20g swapped Turbo legacy if that helps with anything.
Current Cars
Re: Help! Bad Idle
Some times the light will not be on and will have stored codes. This is the first thing you need to do.
Josh, (Site admin) has a great how to on his site and heres the link.
http://www.surrealmirage.com/subaru/engine.html
Charles
Subi-swap94
Re: Help! Bad Idle
If i reset the ecu would that mess up my tune?
Current Cars
Re: Help! Bad Idle
What are you using for tuning?
Subi-swap94
Re: Help! Bad Idle
PP6
Current Cars
Subi-swap94
Re: Help! Bad Idle
also my battery has been disconnected and its still the same as it has been
Current Cars
Re: Help! Bad Idle
Ok, resetting the ECU should not have any affect on your tune.
Subi-swap94
Re: Help! Bad Idle
i have another ecu, that i will be trying out today. and if that doesnt work, does anyone have any other ideas that would cause all this?
Current Cars
