Useful EJ22T Engine Part Numbers and Prices
I just looked through the parts manual and price checked a bunch of common engine parts that get replaced in a rebuild. Thought I would share them since it took a while and it might save someone some time.
The crank and cam sensors are crazy expensive. Junkyard FTW!
Price are by each.
Rear Main Seal $8.59 - 806786010
Timing Hole Plug $4.14 - 11413AA032
Flywheel Crank Bolts $0.64 - 800210660 ( x8 )
Cam Seals $8.02 - 806732050 ( x2 )
Cam O Ring $4.23 - 806946030 ( x2 )
Timing Belt $50.36- 13028AA102
Valve Cover Gasket $10.04 - 13294AA011
Oil Filter $4.74 - 15208AA021
Oil Pump $115.16 - 15010AA103
Front Crank Seal $6.17 - 806733010
Water Pump $86.36 - 21111AA021
Water Pump Gasket $2.86 - 21114AA030
Thermostat $11.48 - 21200AA071
Thermostat Gasket $2.47 - 21236AA000
Collant Filler Tank $101.76 - 21132AA010
AC/Alt Belt $10.76 - 809218140
Knock Sensor $59.58 - 22060AA030
Crank Sensor $251.48 - 22053AA010
Cam Sensor $134.83 - 22056AA070
Spark Plugs NGK $2.78 - 22401AA310 ( x4 )
Clutch Fork Shaft $16.24 - 30532AA000
Clutch Fork Shaft Plug $7.97 - 30550AA000
Clutch Fork Shaft Pin $1.44 - 051905320
Total: $915.11 Before tax and shipping.
Here's a list of all these parts in order from above so you can paste them all into 1stsubaruparts.com and then add/remove whichever parts you'd like and change quantities.
806786010,11413AA032,800210660,806732050,806946030,13028AA102,13294AA011,15208AA021,15010AA103,
806733010,21111AA021,21114AA030,21200AA071,21236AA000,21132AA010,809218140,22060AA030,22053AA010,22056AA070,
22401AA310,30532AA000,30550AA000,051905320
EJ22T Hoses and Vacuum Lines + F pipe
Water pump Hoses
807611232
807611242
807615292
Turbo Hoses
807515712
807611202
807519082
807519222
807505482
Intake Manifold Hoses
807607212
807507412
807519202
Fuel Delivery Hoses
807707130
807503172 ( x2 )
807503182
807506081
Engine Cooling System Hoses
807607362
807907032
807611172
807607922
PCV Hoses
807512181
807415102
807519082
807512952
807512962
807512992
807512972
807512982
F Pipe
11821AA320
Emission Control System
807503422
807503452
807505442
807505432
807505452
807204161
Price are by each.
Water pump Hoses
807611232
807611242
807615292
Turbo Hoses
807515712
807611202
807519082
807519222
807505482
807607212
807507412
807519202
Fuel Delivery Hoses
807707130
807503172 ( x2 )
807503182
807506081
807607362
807907032
807611172
807607922
PCV Hoses
807512181
807415102
807519082
807512952
807512962
807512992
807512972
807512982
F Pipe
11821AA320
807503422
807503452
807505442
807505432
807505452
807204161
I second this notionskid542 wrote:This is awesome. Thank you.
I would like to make the motion that this be stickied.
Also, am I wrong to think this works for the N/A EJ22 as well
Some of these parts are the same for the EJ22 NA but some are not. For instance, I believe the water pump is the same but the oil pump is not the same. It has the nipple for the oil cooler on the bottom of the EJ22T. I was told you can plug that nipple though, or just buy the NA one lol.
I think the cam seals may be the same too and the main seals.
I may have missed some parts too that I could add if anyone thinks of them.
I stand corrected.
You could do that. If you have adobe reader. I just thought it would be nice to have a common rebuild parts numbers thread.
Plus that PDF file is 75MB and some people have dialup still.
kimokalihi wrote:You could do that. If you have adobe reader. I just thought it would be nice to have a common rebuild parts numbers thread.
thats just crazy
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Re: Useful EJ22T Engine Part Numbers and Prices
Wow this really would of helped me before I just did the same thing last night. Took me hours !
Bump For Sticky
Bump For Sticky
No5 for sticky
93 Winestone TW project
Added to the sticky compilation thread.
Solid Petition, 5 signatures. Bill Passed. A tough Goverment indeed
Thanks!
Does anybody actually know the part #'s of the heater Core Hoses
There is some confusion between the Parts Manual and what comes up on subarugenuineparts.com , so I am confused which one to order. I need Inlet & Outlet heater core hoses for my Turbo 5MT SS Legacy. The manual states that :
72015AA020 - Outlet
72015AA030 - Inlet
72015AA090 - Inlet for MT
On the site it comes up different, Please Help. Thanks
Reid.
72015AA020 - Outlet
72015AA030 - Inlet
Reid.
Re:
You're right, That is definitely crazy.....Saskatoon Subaru wrote:kimokalihi wrote:Plus that PDF file is 75MB and some people have dialup still.
thats just crazy
Ok, So I received a lightning fast response from SGP.
The correct #'s are :
72015AA020 - Outlet
72015AA030 - Inlet for Automatic
I will confirm when parts are received !
Can anybody do me a favor and send me a VIN # for a 92 5MT SS
As my Canadian VIN will not register in there system, thanks
72015AA020 - Outlet
