timing help
subiekid
timing help
Post by subiekid »
i searched and read through about 15 posts, but could not find pictures that helped out.
here is a post on nasioc where i asked the question.
http://forums.nasioc.com/forums/showthr ... did=478709
thanks
dustin
1995 Subaru Legacy Sedan - Ruby Mica - Turbo - EJ22T transplant
see my reply on nabisco......not sure if you have those scans or not....
subiekid
Post by subiekid »
yea, thanks josh.
where are the scans of the parts sheets? they are in pdf form right?
everything can be found here & yeah they should be in pdf.
http://www.main.experiencetherave.com:8 ... ual_scans/
For the parts things, there's this
http://www.main.experiencetherave.com:8 ... ts_Manual/
and the black blook parts sheet
http://www.surrealmirage.com/subaru/fil ... Sheets.pdf
