STI fuel pump in 92 SS turbo
stiglogic
Post by stiglogic »
I have been told that I will need to make some adaptations to make this work. Any write ups, or insight anyone could provide would be appreciated. Thanks.
Re: STI fuel pump in 92 SS turbo
Post by SILINC3R »
Is there a reason why you want need the STi pump. Walbro 255 is only like 100 bucks and it is plug and play.
stiglogic
Post by stiglogic »
Yes. I have an STI pump laying about that cost me $0. lol
Got any pictures of the STi pump?
stiglogic
Post by stiglogic »
Not at the moment, but I can take some. If you are trying to figure out if it has the integrated filter, it does.
Curious more about the length/dimensions and electrical connector.
short_round
Post by short_round »
2004 STi fuel pump assembly and 1992 Legacy turbo assembly with a Walboro. The STi fuel pump does fit in the fuel tank of a Legacy no issues, but the only modification would be the fuel lines going to the fuel pump assembly
two of the lines are 1-2 inches short from hooking up to the STi assembly. FYI I have tried!
2013-05-16 12.52.32 by civicbmr, on Flickr
There sure is a lot more shit on the sti pump!
Is that a fuel accumulator of sorts downstream of the pump?
short_round
The fuel accumulator your talking about the white box circumstances the fuel fuel pick up?
No, the round looking device with the cadmium plating and white plastic, kind of looks like a vanilla ice cream cone.
DougFresh
Post by DougFresh »
if you install just the pump i think you would be alright.
IIRC the STi pump flows 230LPH and the walbro flows 255(I think).
stiglogic
Post by stiglogic »
It's just the pump. Not the whole assembly .
short_round
The ice cream cone item is the in pump fuel filter.
Ahhh....ok....stupid in tank filters.
stiglogic
Post by stiglogic »
I pulled all that junk off. I just want to know if this will be plug and play, or do I need to wire in another style clip to fit the STI pump?
DougFresh
Post by DougFresh »
i believe they are the same 2 pin harness. I dont think subaru made any changes to that.
short_round
The two harnesses are the same no differences, they plug in just fine no issues!
stiglogic
Post by stiglogic »
Thank you for that
