map sensor
map sensor
i was changing the plugs today and saw my map sensor just hanging by the connector. does the map sensor need to be grounded to the bracket on the strut tower or can it just hang there
Re: map sensor
Its grounded by the ecu. You should pit it back on the bracket tho.
