I have been trying to see if I could find anything that would have made the bearing fail. I haven't found anything thus far. I do see the clutch was recently replaced. I would say it has less than 10k miles on it so I will be reusing that. All the alignment pins were in place. The rear main seal also looks new and is not weeping so I will leave that alone.
What sealant do you all suggest for the transmission reassembly?
Here are some pics of the process so far.
Neat way to organize the bolts. Had my wife take these shots and I printed them out at work.
Broke open the bearing to check out the insides
The inner race of the rear bearing
Outer race
Ball bearings
Clutch has very little wear, fly wheel has no ridge at all and I can still see where it was resurfaced, pressure plate looks practically new.
Rear main seal. I believe this may have been changed when the clutch was changed. Looks to be in good shape so I will just leave it be.
