retune needed?
ej22evikki
retune needed?
Post by ej22evikki »
Is it a problem if you do not retune a ej22e with a new larger exhaust? Going with a UEL,high-flow cat,2.25" piping and a catback.
Subie gals unite!
Re: retune needed?
MAF based cars don't really need to be "re-tuned" if you make mild modifications. The MAF sensor will detect the added airflow and compensate fueling accordingly.
ej22evikki
Re: retune needed?
That's what I thought but my bfs wrx needed a retune when he did his turboback,so I was just making sure.
Subie gals unite!
Re: retune needed?
These cars have no cheap tuning options.
robertpaige
Re: retune needed?
Post by robertpaige »
Yeah we have OBD1 cars and you can't tune them with a flash or anything like WRX's. You have to get a Standalone or Piggyback ECU to have any sort of tune. You can do a lot with these cars and not need a tune. I had a CAI, 3" turbo back, different turbo at 13psi, and had no issues. Although a tune will unlock so much more power.
Re: retune needed?
ej22evikki wrote:That's what I thought but my bfs wrx needed a retune when he did his turboback,so I was just making sure.
Do you know if he converted over to MAP based setup? If not, a retune might have just helped tweak the ECU slightly. It probalby would have learned to use the turbo back, but I'm guessing one of the main things people tune when putting a turbo back on a newer WRX is the wastegate/boost control. So that may be what he had redone.
ej22evikki
Re: retune needed?
Thanks for the info guys.
Subie gals unite!
ej22evikki
Re: retune needed?
Also,are there any way to increase the fuel capacity into the motor...ie bigger injectors,different pressure regulator.
Subie gals unite!
Re: retune needed?
You can certainly do that, but without a way to control it, your car will run way worse.
robertpaige
Re: retune needed?
You can upgrade from your 380cc pinktop injectors to either 440cc Greytops or 550cc STi Yellowtops, but like Mike said you need something to control it. Either a piggyback or a Robtune. Robtune is awesome cause he tunes for exact setup, whether you have 440's or 550's, what boost you want to run, launch control, etc.
ej22evikki
Re: retune needed?
I haz no boost :(
Subie gals unite!
Re: retune needed?
Upgraded injectors are not really necessary on the non-turbo engines.
