knock sensor wiring splice
hman1991
Post by hman1991 »
The wire to my knock sensor is in pretty rough shape. I am planning on getting a piece from junkyard. Now when I splice it what do I do about the shielding? Solder it together like a wire or just overlap it on its self? Thanks for the help!
Re: knock sensor wiring splice
Probably overlapping it onto itself should be sufficient. If you can twist some of the shielding wire together, that may be better.
