better investment for recent rebuilt motor
turbo970
Post by turbo970 »
trying to decide which would be a better investment on my subie. would a 06 tmic be smarter or a AOS from grimmspeed. i'm leaning towards the AOS do to random start up puffs of smoke. i talked to the rebuild company and they said the rings arent 100% seated yet. i do have 1500 miles or so on the engine
Re: better investment for recent rebuilt motor
I personally don't think an AOS will help the puff of smoke on start up. However an AOS is something worth doing.
The TMIC would be better in my mind, but may be more involved to get everything to work.
turbo970
Post by turbo970 »
so how long does it take for these motors to break in. its a random puff and its not real heavy
turbo970
Post by turbo970 »
is this the tmic that works best on our cars???
http://www.ebay.com/itm/2006-SUBARU-IMP ... 9c&vxp=mtr
It appears so... dont forget to check out the many intercooling threads to find out which additional parts you need, if you haven't already.
turbo970
Post by turbo970 »
sweet i'll order it tomorrow i have some tubing i can use for it. but for the blow off port would a nipple style bolt up so i can run it to my turbo smart by pass valve
turbo970 wrote:so how long does it take for these motors to break in. its a random puff and its not real heavy
On new motors, Subaru recommends 3,000 miles. However, the rings should seat and mostly wear in during the first couple hundred miles. I would think by 1,000 miles they are "seated" as they are going to be.
What type of pistons & rings are you using?
turbo970
Post by turbo970 »
far as i know of they used all standard rings and pistons. but i did notice the oil was a tad over full so i think thats where the puff of smoke is coming from
