Transmission code question
I have a 92 turbo wagon and just got done swapping out the tranny and am getting an error code from the power mode light. It's flashing 16 times when ever I start up the car. Everything seams to be working normally but i cant find what code 16 is. If any one knows where to find this code or what it is it would help a ton. Thanks
Re: Transmission code question
Hi,
Here's the link....http://www.surrealmirage.com/subaru/trans.html
Post back what codes you find.
BTW, You can use the Search - Google bar @ the top to find most everything on here.
GL
TD
GL
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Ok I checked it and it was showing 33 which is the 2 speed sensor, which makes sense because my speedometer stopped working. When you turn on your car and the power light is flashing that is not a code which is what threw me off it blinks 16 times no matter what.
Check the speedo cable or more likely the base piece for the speedo cable. It screws into the trans and commonly fails.
