Dynamic Entry's 4EAT to 5MT Swap (Angel -> Demon)
Dynamic Entry
Re: Dynamic Entry's 4EAT to 5MT Swap (Angel -> Demon)
Post by Dynamic Entry »
Turns out my injectors are probably performing just fine. The report I have does not demonstrate/measure static flow, and Rob said he trusts them based on what they were doing at the "6000rpm" mark.
I have been driving the car pretty regularly now, and everything seems to be operating at an acceptable-impressive level. My electrical issues are no longer present. The wideband still reads lean, and I have come to suspect that is because I am running the JECS maf on the stock ECU. I am still waiting for RobTune to arrive so I can relax and turn up the boost. But the car seems dependable and everything that has been done since I got it seems to have come together nicely.
All that to say this:
I passed my importation inspection and have registered the car.
I consider that to be crossing the line, and that the car is now officially 5MT swapped.
There are many other things that I need to do with it, but they are not technically part of this swap procedure thread. So I will address periphery things elsewhere, and pronounce this particular project completed (or as near as makes no difference).
Thanks to everyone, and especially Josh, that helped make this happen.
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Congrats Andrew!
Glad to hear it's "officially" 5mt swapped!
