rims are 17x7
and tires are 225/55/17
they will go on 90 legacy sedan
will these fit?
jessiethecrux
Re: will these fit?
They might rub and they're 1" taller than the tires I run on my lowered legacy which would rub like crazy if the fenders weren't rolled. Your speedo may be off some due to the taller tires.
Is this a stock height car?
jessiethecrux
Re: will these fit?
It is at stock height yes.
jessiethecrux
Re: will these fit?
nope they dont, the tire wont clear the rear struts.
Re: will these fit?
Thanks for posting back the info.
Do you know what the wheel offset was?
jessiethecrux
Re: will these fit?
45mm on the rims
Re: will these fit?
Going wider with stock struts you'd probably need a lower offset.
Danteandsoob
Re: will these fit?
Dang, I was wanting to go pull some 225's off a junker for auto-X.. ):
- '93 Metallic Blue Legacy L, DD w/lots of mods
- '91 Mazda Miata, Autox fun car
