Small tire difference, wondering if it's okay to do.
Danteandsoob
Post by Danteandsoob »
I have a 93' legacy L AT. Hit a curb the other night, sidewall bulged. Got the REAR 2 tires replaced (5/32") and kept the front two (2-3/32"). Is this x/32 of an inch OK to run? I have NO center differential, and NO limited slip differential.
- '93 Metallic Blue Legacy L, DD w/lots of mods
- '91 Mazda Miata, Autox fun car
Danteandsoob
Re: Small tire difference, wondering if it's okay to do.
Sorry if this has been posted for the 100th time on this forum, I just haven't found and info on subaru's having differnt tread on the front AND back.
And as far as I know, I the LSD's only come on the GT's and SS'..?
Mines just an L, so I wouldn't think it has anything so special.
86BRATMAN
Post by 86BRATMAN »
If your car is awd you need to follow the rules of tires or you risk damaging the clutch packs that transfer power to the rear. You may not have a center diff or an lsd, but that doesn't mean you won't do damage. Subaru says no more than 1/4 inch circumference from the smallest to the largest.
Danteandsoob
So tried spinning the rear wheels and only one turned :/
What does this mean?
And I was planning on changing the front wheels within this summer season, would that be okay on the clutch pack?
James614
Post by James614 »
That just means you don't have an LSD, like 99.9999% of all cars ever made. Perfectly normal.
Danteandsoob
Alright, cool. So if I changed the front tires this season, I should be okay?
No, a difference larger than 1/4" between front and rear tires will wear out your transmission in a hurry.
If you absolutely must swap only 2, put a fuse (5A or larger) in the fuse holder (marked FWD) in the engine bay, passenger side all the way by the firewall. This will convert your car to front wheel drive.
Another option is a used tire place, see if they can find you some with the same tread thickness.
You need to measure the circumference of all the tires. Take a string, drive over it, and wrap the rest around the tire. Mark where the string overlaps, remove the string from under the tire, and measure the distance marked. Do this for all four tires and see what your circumferences are to see if they are within the 1/4" tolerance.
Danteandsoob
I just did, and I'm right at 0.25" or 1/4". Is that OK for now? Was planning on replacing the smaller ones ASAP.
James614
Post by James614 »
You will be fine, just replace the low ones as soon as you can.
