antenna replacement
antenna replacement
What would be the coolest replacement for a stock antenna for a 93 sedan, a shark fin or a carbon 5 in post or something else? Any ideas greatly accepted
Re: antenna replacement
Anything you do, you would likely have to drill a hole in the roof, which I don't know if I'd suggest just for looks.
I usually just run my antenna lower with a few inches sticking out vs. it out all the way. It looks much better. Here's a pic where you can see the antenna just barely up.
http://www.main.experiencetherave.com/s ... G_5396.JPG
92ColoradoTurbo
I saw a Perrin antenna once that was black 4in stub that looked as if it would mate up to the stock location. The guy on the forum was asking $40 for a while but said they retail $80. I thought it would look good matching the stock black trim.
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
I completely got rid of my antenna and hole. Tack welded a piece of sheet metal under it and filled it with bondo. I got a cheap electric ampered antenna and mounted it in my rear windshield. Paid 10 bucks or so on ebay.
I was thinking of a 5 in. carbon antenna as they just screw onto the stock antenna base. That way no drilling or removing of any stock parts other the metal antenna post, which I will keep on hand.
I am with cj only I haven't done it yet. I want to get rid of all the extraneous stuff on the outside.
Jeff
Jeff
Thanks for all the suggestions guys...I am still considering all options, but really don't want the "old fashioned" antenna
Someperson
93 Winestone TW project
That's basically what I ordered from ebay.Someperson wrote:shave it off http://www.amazon.com/Metra-44-UA200-Un ... B0007WRQ8K
Kinda hard to listen to the stereo if I shave it off ...lol. CJ. when you get you antenna from ebay, let me know how it works for you because I really like the looks of it...thanks again
It's already installed. that project was finished, I think, half a year ago or more. The antenna works well, not perfect, but good enough to get radio. Sometimes it can be static sounding but I am not too worried about that, there are other stations. I may have some photos in my build journal.
