Could it be that my brake needs to be bled so the pistons are tighter on the pads? Cause it stops normal, doesn't pull to either side when I brake.
Also, when I'm driving, sometimes the steering wheel will shake until I start to brake, then the shaking subsides until I stop applying the brakes. When I corner right (weight is on front left wheel) and accelerate through the turn, the wheel will screech the whole way till I straighten out or turn left. But it won't screech if I'm off the gas and letting momentum propel me through the turn. Also, if I'm gassing it through the turn, if I give it enough gas it will feel like I'm on ice and start sliding outwards like I'm under steering but the tires don't skid.
I know the best thing to do is replace all of it but funds haven't been on my side this winter so I'd like to only replace one part if I can lol the spare hub already cost me $80 and the parts store sells a reman'd dual piston caliper for $90
A
Any ideas on what's up with my car would be great!
