Most of the bulbs were replaced with the same led module. The door/courtesy lights use a smaller festoon bulb than the map light and dome light, but the new led still fit, though it was pretty tight.
The original bulbs are festoon style incandescent. You can see the size difference in this picture. The dome and map light bulb is on the left and the courtesy lights bulb is on the right.
The replacement modules were either red or white.
Map Light:
Dome Light
License Plate Light:
This area uses a wedge shaped bulb.
I ordered everything from superbrightleds.com. Here's the parts list:
License Plate: http://www.superbrightleds.com/moreinfo ... tower/910/
Courtesy Lights & Dome Light: http://www.superbrightleds.com/moreinfo ... stoon/238/
Note, this is the same module as the map light, just a different color.
