1991 Legacy Wagon w/ or w/o ABS?
scoobydrew
Post by scoobydrew »
I'm looking for a proportioning valve that comes with a Subaru equipped with a no ABS but 4 wheel discs.
There is a 1991 Legacy wagon at my local junkyard with 4 wheel discs, but I cannot figure out if it has ABS (or if someone has already claimed the ABS controller/pump). I took a look at it, and I cannot find the ABS pump. The brake proportioning valve is black and about 5 inches long.
According to Cars101.com, 1991 Legacies came with 4 wheel discs and ABS.
Can anyone help?
Re: 1991 Legacy Wagon w/ or w/o ABS?
Welcome to the BBS.
This is what the non-abs proportioning valve looks like:
http://www.main.experiencetherave.com/s ... valve1.jpg
http://www.main.experiencetherave.com/s ... valve2.jpg
You can also look at the brake master cylinder if it's still there. If there are only 2 lines coming from the MC, the car had ABS. If there are four lines coming from the MC then the car did not have ABS. Also, the non-ABS MC has a 1" bore, while the ABS MC has a 1-1/16" bore.
Here are pics of the ABS 1-1/16" bore MC.
http://www.main.experiencetherave.com/subaru/images/MC/
scoobydrew
Wow this is REALLY good information. Thanks for your help!
You're welcome!
Look on the frame rail immediately behind the passenger headlight in this pic:
Even if someone removed the ABS pump, there would be evidence of it, such as the 4 brake lines going to where it was. Also, on the passenger strut tower you can see that my example has a different proportioning valve from those Legacy777 posted, for your reference.
If you need a proportioning valve, I have one. It's a non ABS valve from my 1991 wagon I had back in 2008. Make me an offer...
Nohbdy
Post by Nohbdy »
I have to agree with Mike even with the pump gone its quick to notice. My 91 didn't have ABS and the ones that did or do I almost always see stickers somewhere on the car that mention if it has ABS.
91 Legacy L (AT, FWD)-crashed 2/3/14
95 Legacy L (AT)
05 Outback XT (AT)
92 Legacy L (MT,AWD)
