ABS? Cruise control? I have no such thing.mike-tracy wrote:If you're trying to find someone who has done it, maybe look at newer cars that came with both phase 1&2 transmissions in the same body. Such as the 1st generation impreza, and the 2nd gen legacy.Burnera wrote:Has anybody done it with usdm WRX stuff and failed?
Even if you could rewire your whole car just to run the WRX tranny, would you really want to lose the functions tied into the phase 1 transmission ecu? Such as, ABS, Cruise Control, and other functions? Or were you thinking about swapping and rewiring those in as well, from the WRX?
Current thought is...
If my final drive is 4.11....swap over the center diff and rear LSD from an 02-07 AT WRX, fuse jump the TCU.
if my final drive is 3.90....swap over center diff from AT WRX and rear LSD from a MT WRX, fuse jump the TCU.
(If i could find a full swap, engine included, at a reasonable price, i'd do it, but i'm not seeing many donor cars around and i don't have the money saved up right now either. )
Seems like at some point, you just have to try and document your efforts, since there is a lot of conflicting information.
