Clearances are very small that just starting to slide it back on isnt easy. It has to be completly neutral if you apply force in any direction you will get hung up.
Then you have to align three different units (tabs on the inside and two splined units). Problem is the center shaft of the transmission also slides out. We spent a couple hours total messing with it until we finally realized the center shaft wasnt inserted all the way. Getting the center shaft to slide back in takes a while to since it has super tight clearance and THREE splined sections.
It was actually luck both times I got the shaft and TC all the way on. We had been messing with it for so long we had become punch drunk. I played around and said "presto" as I lightly touch the shaft and DUNK, it went in. We all looked at each other in amazement. It was similar when we tried to install the TC. We would pull the TC out a few MM, turn it 2 degrees and slide back in. My bud did this for 15 minutes with no success. Finally I cant up and PLUNK, it goes right in.
We all just starting cracking up.
Never work when you are tired. We bolted everything all up (three guys) and when it came to attach electrical and intake I realized we forgot to install the TC to flex plate bolts
I was so relieved to see that the TC could turn (after removing the starter that I had installed 4 fucking times already).
Now we just have to get all the intake, fluids, exhaust and drivetrain back together and our 300$ AWD legacy will be ready for fun
