Silinc3r's 05 Legacy GT/SpecB update 03/2015
Re: Silinc3r's 05 Legacy GT with more Spec B
Stupid Japan.....
Thanks Mike. For some reason I thought Tony had said somewhere that his was a Spec C.
Post by SILINC3R »
beatersubi wrote:Thanks Mike. For some reason I thought Tony had said somewhere that his was a Spec C.
Noooooooo
Post by SILINC3R »
Ok pictures are up. Spec B 2006 Red Brick Leather seats. I now have a unicorn SWP 2005 GT. They only made these seats for the 2006 model Spec B.
Spec B rims also!
JDM STi Genome grill
Also have JDM Aero Spats that will need to be put on later. Lucked out on the grill and it was already SWP so I jumped on it. The spats will need to be painted.
Post by SILINC3R »
Forgot to put up this too.
And for some reason I didn't take any photos of when I did the breaks. Stoptech all the way around pads and slotted rotors with braided lines! Just need new tires for the rims.
dankberries
Post by dankberries »
Crown Royal bag shifter boot?! That is sweet!!
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
CFK
Post by CFK »
WOW ! So Nice :!: That looks like Euro Fit & Finish !
The Grill looks aggressive< maybe to Aggressive :?: ( IMO )
Very Nice Car :smt023
Build Thread : HERE
92 SS 5MT. Project Daily
84 Jetta Coupe. Real Project
99 A4 Avant. Wife's Daily
Post by SILINC3R »
Thanks for the comment guys. Yea not to sure of the grill yet. But it is something different. Kind of reminds me of a boar.
So over the weekend I finally had the time to do the suspension swap to the BC BR coilovers. Had issues initially with hardware being seized so I just bought all new hardware.
And so I would never have problems again I used the same techniques I use working on aircraft.
And this was odd, notice the difference
Finished
Still have a little fine tuning to do. Lowered the height in the front again today.
Is that spray-on anti-seize?
Are you adjusting by corner weight or visual ride height?
Post by SILINC3R »
It is a spray on corrosion inhibitor. Really great stuff. Right now it is visual, i would like to corner it in the future.
Post by SILINC3R »
Well here's your problem
Yup....that'll do it ;)
Post by SILINC3R »
Alright so BIG update 8/21
Repaired and painted the Spec B rims, rebuilt and painted stock rear calipers and Brembos. All 4 rotors turned and new pads installed with Stoptechs. H&R 15mm spacers with extended studs installed as well. Muteki lug nuts.
On a side note I have a 90 Miata with no ABS and a 91 Legacy Turbo. When I bled the brakes I did it like 3 times because I had forgot what the LGT brakes felt like, mushy. I was like this can't be right but that is how they are.
Kind of gives you an idea of the extreme colors.
New boots
Stock rear caliper bracket bolts
Turned rotors for the Brembo fronts. Same size as the LGTs but the contact area is larger.
Should have stuck a ruler next to this. Using closed lug nuts.
Re: Silinc3r's 05 Legacy GT/SpecB update 8/21
You and your cool parts, Tony! so...uh....I can haz your old LGT rear calipers?
Post by SILINC3R »
mike-tracy wrote:You and your cool parts, Tony! so...uh....I can haz your old LGT rear calipers?
I didn't upgrade the rears just the fronts
Ooooo... I gotcha. Front brakes look good.
What paint did you use to paint the wheels? I like :)
Post by SILINC3R »
Legacy777 wrote:What paint did you use to paint the wheels? I like :)
The rims were
Cleaned
Sanded
Bondo'd
Sanded
Cleaned
Primed
Black gloss base coat
Colorshift paint
Clear coat
Galaxy Blue
Cool!
Post by SILINC3R »
So instead of going out with friends on a Saturday night I decided to spend 12 hours working on the interior of the car! Finally installed some gauges with the cubby pod. AEM UEGO wideband and Prosport Halo boost gauge. I also installed an air filter since mine never had one, cleaned up some wiring from the previous owner and installed my Spec B steering wheel. I am very pleased with the way it came out and love the location I found for the pressure sensor.
Spliced into the clock
Pressure sensor location.
Well after 10 years and 100,000 miles it finally has a cabin air filter!
Unfortunately I had to do some cutting to get the best fittment with the AEM wideband
Re: Silinc3r's 05 Legacy GT/SpecB update 10/6
Tony,
Is that pressure sensor for the boost gauge? Did it come with that little inline filter?
Post by SILINC3R »
Legacy777 wrote:Tony,
Yes sir, electronic boost gauge. And yes the filter came with it, as well as the sensor. Awesome price. Highly recommend prosport gauges.
DLC
Post by DLC »
Lovely BL. Lots of nice parts. Unlimited is how I would have gone, but the BP instead. Too bad the market is still very strong for those rare birds.
(see signature)
Legacy Central
Post by SILINC3R »
So I've been bad with updates. Installed front and rear JDM aero spats, front lip, carbon fiber hood scoop and roof spoiler, engine dresses up, STi Genome strut bar, painted the grill and the strut bar, painted the spats.
This picture doesn't have the spoiler or scoop installed
Scruff_
Re: Silinc3r's 05 Legacy GT/SpecB update 03/2015
Post by Scruff_ »
That grille looks amazing!!
1991 Subaru Legacy SS 4EAT (awaiting manual swap)
1994 Subaru Legacy TW
2001 Toyota Sequoia
