Legacy777's 1990 Legacy Turbo
Re: Legacy777's 1990 Legacy Turbo
Ok, what you've all been waiting for......DYNO PLOTS!
The dyno plots can be a little confusing, especially when there are more parameters being plotted. I've tried to label the plots as best I can, but if you have questions let me know.
All the new dyno plots can be found here in my normal image gallery.
One of the plots shows the HP & torque with and without the SAE J1349 correction factor. Here is a little more information on the SAE J1349 correction factor.
Also, I've listed all the dyno plots below. (click image for hi-res version)
HP Test Results Summary
255 hp & 306 ft-lbs at the wheels
New Motor & Tune vs. Old Motor & Tune
New Motor & Tune vs. Old Motor & Tune (with and w/o SAE corrrection)
Josh's 1990 Legacy vs. 2002 Stock WRX
Josh's 1990 Legacy vs. 2006 Stock WRX
Josh's 1990 Legacy vs. 2006 Stock STi
Josh's 1990 Legacy vs. 2008 FLi Stage 1 STi
Josh's 1990 Legacy vs. Rod's 1992 Unichipped & Turbo'd Legacy
Post by SILINC3R »
Dang!!!! I know a lot of guys that would be pissed if I had those kind of numbers around here. Love that torque though
Some good numbers Josh!
macipusy
Post by macipusy »
I like all the comparison data. Nice that the performance is better with less boost this time around.
The power output really gets put in perspective with the WRX/STi output curves.
You definitely squeezed out a pinch more then I did on my 91 SS running E85.....by like 5 wtq and 5 whp.
Great Numbers!
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
Thanks guys!!
Yeah it's definitely fun to drive, and while larger injectors and turbo would probably squeeze a little more power out of the engine with more boost, I'm sure I'd lose a bit of the low end power & add turbo lag. There is very little lag...the engine builds boost extremely quickly. I need to take some logs and will post some graphs of boost vs speed, etc. I believe I can even get 0-60 times from the data in the ECU.
All the different graphs and data really paint a picture for comparison. Dyno data is kind of useless without having that wide range of comparison data. You can definitely see that the heads (HLA's) really limit the higher rpm's. Even if the heads were ported I'm not sure I'd be able to pull or rev much more out of the motor. Anyone know if they make a conversion rocker assembly for the ej22t heads?
James614
Post by James614 »
I'm loving the gains on the low-end. Area under the curve FTW.
bmxpunk
Post by bmxpunk »
That is incredible Josh! I love seeing progress on the older cars. Maybe I should check-in more often...
And this is on stock 22t heads? You haven't got the bug to swap to dohc heads yet? Didn't that free up 30-40hp on a stock 22t for MMonson?
2011 Mini Countryman S All4
1970 Honda Ct90
2001 Forester S of Doom - mowed down by a Cummins
1994/5/6/01/02/03/04/06/07/08 Impregacy OUtback SS STi Type R money pit- NEW RALLYCAR!!
bmxpunk wrote:That is incredible Josh! I love seeing progress on the older cars. Maybe I should check-in more often...
Thanks Tyler!
Yes this was on stock 22t heads with Delta Cams' 220 "Torque" grind. If I swap to DOHC heads I'll need a different intake manifold and will have to completely redo how everything is laid out and I do NOT want to do that. I know the heads are the limiting factor, but I just don't want to redo everything. If this motor goes I will seriously consider putting in an ej257 since the variable valve timing can provide a flatter torque curve across the entire rev range and I can use my same ECU to control it.
I'm hoping just to be able to happily drive my Legacy for a while without having modify/work on things :)
wtdash
Post by wtdash »
Legacy777 wrote: I'm hoping just to be able to happily drive my Legacy for a while without having modify/work on things :)
Oh, Josh...that's a good one! LOL! :D :lol:
Glad it's running well.....and you're liking the ride.
Happy Holidays!
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Post by SILINC3R »
Happy Holidays!
Td
Heard that one for sure but I am in the same boat. It is finally running well with the new stuff. Time to enjoy!
I played around the camera and made videos of the speedo/tach start up sweeps.
http://bbs.legacycentral.org/viewtopic. ... 71#p432571
Post by SILINC3R »
Haha I forget the gauges are green. Changed em to red long time ago. surprised you havent as well. Awesome none the less.
Luckly I never installed the cluster so there is still hope for a rebirth
I wouldn't mind red gauges, but I'd have to change everything and I have plenty of other projects :)
I got a slightly updated tune in the car this weekend to adjust some cold starting and spots in the MAP. The car felt good and when I was doing some testing I hit the rev limiter (very easy to do now) and due to the type of rev limiter and no cats I got a nice "pop" like you hear on the rally cars. I'll have to see if I can hook up my gopro camera near the rear of the car and get some video/sound of it. It sounds pretty wicked :twisted:
macipusy
Post by macipusy »
I have done the same type of rev limiter bouncing in the RSTi, especially in 1st gear....sounds bad ass when it happens. That redline comes quick when you got some go juice....haha
On the rev limiter settings, do you have it set up as a soft fuel cut or hard? I think mine is set to soft cut over 200 RPM duration.
maciek puszynski
16 WRX | 6mt | fa20
Post by SILINC3R »
Legacy777 wrote:I got a slightly updated tune in the car this weekend to adjust some cold starting and spots in the MAP. The car felt good and when I was doing some testing I hit the rev limiter (very easy to do now) and due to the type of rev limiter and no cats I got a nice "pop" like you hear on the rally cars. I'll have to see if I can hook up my gopro camera near the rear of the car and get some video/sound of it. It sounds pretty wicked :twisted:
Josh you need to get the GoPro mic adapter, 3.5mm extension cord and then a 3.5mm lapel mic so you can get good pick up. Then you can keep the camera inside. Total cost is about 100 bucks but it is so worth it. GoPro mic sucks.
macipusy wrote:I have done the same type of rev limiter bouncing in the RSTi, especially in 1st gear....sounds bad ass when it happens. That redline comes quick when you got some go juice....haha
With the current MAP it's setup for hard cut using fuel. I had thought my previous MAPs were setup with a soft cut, so I need to check back in with the tuner to see if he changed it to a hard cut and why.
SILINC3R wrote:Josh you need to get the GoPro mic adapter, 3.5mm extension cord and then a 3.5mm lapel mic so you can get good pick up. Then you can keep the camera inside. Total cost is about 100 bucks but it is so worth it. GoPro mic sucks.
Tony,
I still have the old school GoPro Hero (Not 2, 3, or 4). Do you know if the lapel mic works with the original camera?
Post by SILINC3R »
Looking online it looks like a no. They show the Hero 2 having a mic icon on the lower input but on the Hero 1 that icon isn't there.
Ok, thanks Tony.
That sucks.
imtb
Post by imtb »
Super clean build, its nice you have had the car for so long. Now I know how you know so much about the Gen 1.s
Hi Mike!
Welcome to the BBS.
Yeah, I've had my car for quite a while now and have picked up a bit a knowledge along the way to share :)
I had the car out today to do some logging and driving in the nice weather. It was warmer today and one of the things I noticed again was a fuel vapor smell. I had this occur before when temps were warmer. I attribute it to not having the auxiliary purge setup on the charcoal canister and the engine isn't sucking in the fuel vapors enough.
So I have a dilemma....what to do now. I can either cap off the lines and disable the canister purge and have very long hissing spells at the gas station or fab up something to run the auxiliary purge again. Or possibly see if there's some other solution out there.
Any ideas/thoughts?
The hissing never bothered me. Never had a problem either. That's 6-7 years of driving too.
I have the same problem. My fuel vapor line is just vented under the hood. Sometimes I smell fuel. But the odd thing is that I still get the hiss from the gas cap same as when that line had a cap on it. I think I will just cap it again. Better than having lingering fuel vapors for no reason. The hissing gas cap doesn't bother me as long as the pressure in the tank won't cause a problem. My ecu has no purge solenoid function I'm told.
