TD04 straight forward, unbolt vf11, reverse order TD04 on it. just need a silicone 90 for intake yes?
06 tmic.
I have to cut the clutch reservoir down to 2" .
move the radiator fill resevoir over a little bit for some more room.
Get a 45 elbow fabricated up to reach the Y pipe off the intercooler.
The thing I believe I'm missing is what to do with the BPV...i was thinking block off plate since I'm running a atmospheric dump...and also the culprit why the car is running pig rich
And I need to let it breath by doing 3" turbo back exhaust unless you believe 2.5" will suffice.
Any thoughts would be appreciated.
