Bucking and hesitation issues
Re: Bucking and hesitation issues
I'd say I might have a spare ECU if you're driving through Reno but mine does something similar, mostly doesn't do anything exciting under boost and occasionally bucks on me. I've learned to work the clutch to limit the bucking. Figured I'd look into it again if it did it after the new engine's put in with the RobTune. Hopefully it stops with the new setup, driving to Tahoe from Reno is getting annoying in my car.
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
My 05 lgt is doing the same bucking and vibrating on start up and rpm drop when you put it in gear it's not shutting off tho
I think that might be something else. Im also am having a problem with my AWD. Im thinking its my duty c solenoid. The percentage of my tire spin is being weird. It causes the car to loose torque. At the same time it could also be my bad ECU.
