Moderators: Helpinators , Moderators
robertpaige
Posts: 1232 Joined: Tue Jul 31, 2012 10:32 pm
Post
by robertpaige » Thu Jan 01, 2015 2:53 am
So my ebrake handle stopped working, I took it apart and found the cable snapped where it connects to the handle.
Is there anyway to fix the cable? Like a way to re connect the broken part? Or do I need to run a whole new one from a donor car... Grrrr
thewaterboy
Posts: 191 Joined: Sat Sep 27, 2014 7:57 pm
Post
by thewaterboy » Thu Jan 01, 2015 3:11 am
Duct tape solves all.
On a more serious note, running ebrake cables isnt that hard. Shop time for an E30's cable is 6 hours, but my buddy and I did his in 45 minutes. Not sure if you've messed with the ebrake at the hub at all before, but I've opened up this one a few times and would gladly offer up any help needed.
rallyak
Posts: 896 Joined: Wed Oct 26, 2011 7:02 am
Post
by rallyak » Thu Jan 01, 2015 4:43 am
The cable you have in your hand is short and it connects the two cables into one. I would grab one from a salvage yard, it just under the console.
I've also changed my e-brake cables I would say 11/2 hours.
Charles
90' White/Gray Outback DD workhorse (670,xxx ) miles
robertpaige
Post
by robertpaige » Fri Jan 02, 2015 8:57 am
Yeah I realize now it's the small cable that connects to the others, so that should be easy to replace! Thankfully
