Humor me (WRX mid-pipe + muffler)
So, the parts car I bought came with a borla clone header; if I had a shop fab a j-pipe with a bung and cat, then have them move/extend the mid-pipe and hangers, and fit the muffler.
Would this work? Also it's for an N/A car.
- '93 Metallic Blue Legacy L, DD w/lots of mods
- '91 Mazda Miata, Autox fun car
Bolt up a forester cat to an exhaust of your choice, aaaand done
A4 LM7 Drift build: http://www.audizine.com/forum/showthrea ... or-shut-up
Re: Humor me (WRX mid-pipe + muffler)
So is that bolted up to a WRX midpipe, or to the existing midpipe?
This is the borla rep and forester cat. I bolted it up to an aftermarket SS exhaust. Its been said many times on here though, that if you want to use WRX/STi stuff, it will need some cutting/modifying.
Right, right. I guess it's better then having a shop fab something custom w/a cat.
Exactly. I got my forester cat for $30 on CL. It has 2 O2 sensors, so I just left the rear one in, but snipped the wires. It sounds great and I got a nice little power boost from all this!
So you saw some power gains from the exhaust swap? great!
Well, I had this going on: https://vimeo.com/116279878
So running open header on one side, the other running to a cat with 280k on it, to a rusted through tiny stock exhaust. The exhaust I went with is a 2.5" setup. I still keep backpressure, while sounding good
Hopfully ill get to UPAP tomorrow to grab a similar cat section. I realize that adding a cat is bad, but i'd rather put it on an forget about it
After I change the header my custom skidplate will go in
You won't be able to buy a cat section used, from any business.. Its illegal and carries thousands of dollars in fines for the company.
That being said, used cats change hands all the time on craigslist and elsewhere.
*sigh* seems no one is selling any cats that will fit with the headers in my state..
