Long time since I updated on here again. So bulk copypasta.
Bits from the first car moved onto the second and now all the best bits of all 3 are on the red one.
With which I guess I should update this thread, been busy over the last month or so.
As much as I'd been enjoying the new RS there was a couple of things I wasn't happy with. Gearbox was slightly crunchy in 4th and engine although the original for the car was very dirty had some leaks and was slightly low on compression in cyl 3.
So I decided after some uhmming and ahhing to yank the engine/box out of the grey car and chuck them in the red one as well.
https://www.youtube.com/watch?v=XHp7e8ASohw
Cool GoPro timelapse video my mate put together.
Whilst I was at it I fitted the V5/6 power steering setup, Koyorad and LCA's with Whiteline ALK and near new balljoints. I also rebuilt the power steering pump with new seals & O rings before chucking it in.
Fresh pump, had actually been badly sprayed black for some reason so took a bit of effort to get it as clean as it now is.
Which meant sorting a different solution for powering my aftermarket bits. Chopped up my ISO loom, cut a pair of stock plugs out of a car at pickapart and now my boost gauge works again.
Finally for this update had a bit of spare time this arvo to sort some little bits and pieces.
Installed a Jason M pipe to replace my previous resonator delete for a bit of a cleaner look.
Made a quick fire extinguisher bracket.
and installed my boost controller. In the first RS I had the solenoid mounted where the AC receiver drier goes as it didn't have AC. This meant in order to keep my AC I had to think about a good spot for it to mount fairly easily. Took a while but thanks to something I saw on the DOBC forums I ended up with this solution.
Bracket mounted off one of the igniter bolts.
Tight fit down there but it keeps everything neat and as a bonus is even closer to the turbo than the stock solenoid.
Tiny update time.
Since I've had this car the AC clutch bearing has been squealing with the AC turned on which has been pretty irritating especially seeing as it's summer. Had swapped the bearing section with one off a space compressor I have but it wasn't really a whole lot better so I decided this evening to fix it properly.
It would've cost $300-400 for a new clutch assy, total spend for the bearings and belt was about $50. Definitely worthwhile.
New bearings for the clutch and tensioner as well as a new correctly sized belt as the one fitted was undersized and incredibly difficult to remove and refit.
For anyone with an early Denso compressor interested in doing this themselves part numbers are as follows.
Clutch bearing - Nachi 30BG05S2G-2DS
Tensioner Bearing - UBC 6301-2RSC3EMQ5
Belt - 4PK890
Clutch disassembly is pretty easy.
Remove the 10mm nut on the front, wiggle the front section off(Be careful not to lose the shim that sits between it and the compressor shaft) Then remove the circlip retaining the pulley section and slide it off the housing.
Use a punch to smack the old bearing out and a suitably sized socket or an actual drift to smack the new one in and re peen over the edge. Tensioner is pretty much the same process.
Put it all back together and enjoy your now quiet AC.
Another quick evening project. Rebuilt WAIC pump.
Only replaced the centre bearing as the bearing at the end was perfectly smooth and felt almost brand new. Cleaned everything up, replaced O rings and the centre bearing. $10 total cost.
Couldn't get the seal between the pump and the electric motor either so am hoping it is alright. Seemed nice and supple still.
Was interesting to find out as well that the bearings used in the pump are the exact same dimensions as skateboard bearings.
Is a lot quieter now, can barely hear it.
Well guess I should update this thread. Been a few changes to the RS lately.
For now I'll just leave you with this. Grey RS is gone and I have a new addition to the stable.
Anyway guess I'll update going on with the RS. Been a lot of ups and downs with it lately. Trying my patience that's for sure. I'll try to keep it relatively in order.
Flew through roadworthy after all the work I'd done over the last couple of months. Wiper blades and clutch fluid bleed. Now rid of those awful yellow plates! Spent the extra for black plates too. Looks a lot neater imo.
The single bolt coils I'd bought started crapping out too unfortunately. Contemplated buying a new set but since the AUD's gone to shit they're a lot more expensive than they were when I'd previously looked at them. This led to searching for the best product to reseal them effectively. Pack of JB weld, left overnight and they've been perfect ever since. Great $12 fix.
Installed a V2 STi 6K ECU. Feels stronger and smoother throughout the rev range and loves to pop and crackle on decell now. A lot more fun.
Hit a milestone!
Installed the door decals from Seans sticker pack. Awesome pack.
Picked up another sunroof glass with a better seal. Still not perfect though.
Said goodbye to the grey RS
Bought a VF24 for cheap.. too cheap. Got it in. Felt awesome for about an hour then seized
back running the VF12 for now.
Now since installing the ECU my clutch had been slipping some. It got worse during the short time the new turbo still worked then really bad in the couple of weeks following. Once I got it out could see how bad it really was. Started chewing on the rivets :S
Got bits and pieces together. Near new Exedy Heavy duty organic, Flywheel out of the grey car machined, HEL braided line(This ended up being no good so has been sent back. Looks like the threads on the hard line end weren't tapped far enough down into the fitting so it wouldn't seal) Spigot bearing, fluid etc.
Old vs New
Glad I had the spare flywheel too. Noticed after pulling the old clutch that whoever machined the fly last didn't think dowels were important o.O
New clutch feels awesome. Engages pretty much right off the floor. Heavier pedal as to be expected which is nice. Definitely a more positive feel all around.
Picked up some coilovers off ebay. Tanabe Sustec Pros. Still waiting for rears(Have been sitting in a mail centre in QLD almost 2 weeks
) But fronts are in the car. 10KG swift springs which I thought would be damn harsh though they actually feel reasonable. I may end up going a softer spring depending on how it feels with the rears in.
Bit of a difference in droop.
Just after fitting, have bought it up a little since and may need to bring it up a bit more. It's rubbing on the guard lip under anything more than very slow cornering and I've lent my guard roller to a mate.
Picked up some alloy front LCA's too. Just GC8 STi/B4 arms so no extra castor or track. Will freshen up with Superpro bushes and new endlinks before they go in.
Lastly for this update. Had one of those "OH SHIT" brain farts the other day before leaving to go to the meet at docklands. Checking over a few things in the bay whilst the car was running, noticed the turbo oil feed looked like it was weeping a tiny bit so I decided to nip it up a little.
Not thinking about what I'm doing, grabbed my big 1/2" breaker tightened it a little and the bolt snapped :dash2:
Luckily I had a spare and could get the snapped off thread out of the turbo without a hassle.
That's it for now, thanks for reading.
